20 Most Recent
Kodak Easyshare CD82 Digital Camera Questions & Answers
Camera broke
your camera is broken. get a new one. they do wear out, you know. if it is new, return it to the store with the receipt, and get your money back.
I have a Kodak Easy Share CD82. What do the designs on top of the dial mean there is one red design What does that mean?
In order, starting with the "P"
P - Program - Access to more manual settings than Smart Capture mode.
"hand" - Blur Reduction - Reducing blur caused by camera shake or subject motion.
"VIDEO" - Capturing Video with sound
(red colored camera) - Smart Capture - General picture taking - it offers excellent image quality ad ease of use. The scene is analyzed for other content and for lighting. You can choose the best picture size and aspect tatio for your needs - just press the Menu button and choose picture size.
"Flower" - Close up - Use available light instead of flash, if possible.
"Sport" - Subjects that are in motion.
"SCN" - Scene - Point-and-shoot simplicity when taking pictures in practically any situation.
You can download the PDF file by Googling your camera make and model. I'll try adding it here with the link. You might have to copy and paste to your own browser.
Hope this helps. Mike
[PDF]
KODAK EASYSHARE CD82 Digital Camera
resources.kodak.com/support/pdf/en/manuals/urg01070/
CD82_xUG_GLB...
KODAK EASYSHARE CD82 Digital Camera Extended user guide www.
kodak.com For interactive tutorials: ... Use power-saving
features (see Using the Setup tab, page 28).
How did my memory card get protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Why can't i hear my video?
The CD82 records sounds when recording a video but does not play them back. Transfer your video to a computer and play it there to hear the audio.
Need software for cd82
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa (
http://picasa.google.com ).
Broken door
i can only say bring it to the dealer where u bought it and let it repair
My kodak easyshare has a white screen
Hello, Go to Kodak website under support and downloads and find the firmware download for your CD82 camera and see if that corrects the problem.Best Regards, Russell
Easyshare cd82
Hello Bob, Sounds like drive assembly failure, the plastic gears strip and the pieces jam the drive motor assembly. No battery will help this problem. This is a high dollar repair.Best Regards, Russell
Unable to upload pictures
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
