20 Most Recent Kodak EasyShare C1013 Digital Camera Questions & Answers
The sd memory card : i can't push it when i did it didn't work but suddenly it pop up
Did you try to put in another card already? Just to establish if the defect is in the camera or in your card. When you push in the card a little pal will lock the card in the camera. If the card lost a little of its outside, it could be the lock is not ok. I'm afraid something is wrong with the pal in the camera. But you need a good set of eyes, some knowledge how the card locks in and a peek into the card holder, to see if it works correct.
12/26/2013 9:43:39 PM • Kodak EasyShare... • Answered on Dec 26, 2013
Kodak 1013 will not switch on
Well sounds like shop time for another Kodak.
1/25/2013 4:53:55 AM • Kodak EasyShare... • Answered on Jan 25, 2013
No sound on video play
The camera won't play back any audio. To hear the sound, transfer the video to a computer and play it there. See this page of the extended user guide.
12/14/2012 2:06:30 AM • Kodak EasyShare... • Answered on Dec 14, 2012
How do upload photos from camera to laptop?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
11/14/2012 4:51:31 PM • Kodak EasyShare... • Answered on Nov 14, 2012
Removing sd card
Open the battery/card door. Gently press down on the card with a fingernail and it will pop up slightly. Grasp the card with your fingertips and pull it out.
3/9/2012 9:22:09 PM • Kodak EasyShare... • Answered on Mar 09, 2012
Kodak easyshare c1013 lens stuck out ... how to rectify it ?
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:And here's a video summary of the steps:
1/2/2012 6:58:02 PM • Kodak EasyShare... • Answered on Jan 02, 2012
My kodak easyshare c1013 turns off when i connect
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
5/2/2011 7:25:38 PM • Kodak EasyShare... • Answered on May 02, 2011
My Kodak EasyShare C1013 keeps telling me that the
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
2/11/2011 9:24:35 PM • Kodak EasyShare... • Answered on Feb 11, 2011
My camera turns on and off normally, i have the
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
1/3/2011 9:54:25 PM • Kodak EasyShare... • Answered on Jan 03, 2011
Wont turn on
Check on the battery for voltage, if not charge and try again. make sure the contacts are clean and the terminals are tight.
If not you will need to open the set to check for failure in the power supply within the camera. Check for open fuse links ,failed regulator or a faulty control panel.
12/18/2010 10:30:19 AM • Kodak EasyShare... • Answered on Dec 18, 2010
Need manual in memphis,tn.thankyouverymuch
User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18969/kw/c1013
Extended User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/18966/kw/c1013
11/12/2010 6:11:49 AM • Kodak EasyShare... • Answered on Nov 12, 2010
I cannot find the instruction
You can view the manual online and/or download a PDF version from
http://www.kodak.com/global/en/service/products/ekn035313.jhtml?pq-path=13239
10/23/2010 7:19:29 AM • Kodak EasyShare... • Answered on Oct 23, 2010
My camera is not on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 4:19:00 AM • Kodak EasyShare... • Answered on Sep 27, 2010
I have a Kodak easy
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
9/2/2010 3:48:12 AM • Kodak EasyShare... • Answered on Sep 02, 2010
0answers
How to reset kodak c1013
Hello
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
8/27/2010 10:33:15 PM • Kodak EasyShare... • Answered on Aug 27, 2010
The camera will not switch on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
6/12/2010 10:27:28 PM • Kodak EasyShare... • Answered on Jun 12, 2010
Kodak EasyShare C1013 Digital Camera Logo
30 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
no sound video play
  • Cameras
