20 Most Recent
General Electric W1200 Digital Camera Questions & Answers
How to download from the W1200
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
What numbers on camera screens corner that's f3.0 1/30 ISO 200
f3.0 is the size of the lens opening. The larger the number, the smaller the opening.1/30 is the shutter speed.ISO 200 is the sensitivity speed of the sensor. The higher the number, the less light you need for a good picture. For example, 400 is twice as fast as 200...800 is 4 times faster, etc.
Why does my camera have
It's likely caused by issues with the sensor that's within the camera. Are they consistent white lines and are they there in all modes?
How do you get write protect off the screen of a
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card.
Shutter is stuck open on the digital camera w1200.
I think what you're referring to is the lens assembly not moving in and out correctly. The shutter is inside the camera out of view. Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Need to find a web
Start with this entry into your web browser:
When I turn on my
If the memory card is an SDHC card then that is probably the problem. Look at the card, does it say SD or SDHC? I don't believe the camera can use an SD High Capacity card.
If it's a regular SD card, then check the "Lock" switch on the side and make sure it is not set to "Lock". If it's NOT set to "Lock" and NOT an SDHC card, then the problem is inside the camera. There is a small switch on the mainboard of the camera that the little "Lock" switch on the memory card pushes. If that switch is damaged then it will not be pushed by the switch on the card properly and the camera will think the card is locked.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
I got a w1200 digital camera for xmas. I just niw
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
How can i down load
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( htpp://picasa.google.com ).
