20 Most Recent Jabra Bluetooth Car Kit with Night Driving Mode Tripod Questions & Answers
How do i pair my hfs001
Hello, Press and hold the "Answer/End" button for about five seconds. When you hear "Pairing Mode," the speaker is now discoverable by other Bluetooth devices. Turn on your cell phone;s bluetooth connectivity. Once your cell phone has found the HFS001 it will ask for a pairing code the code is "0000". The phone will then connect to the HFS001. Enjoy your hands free experience!
4/7/2013 2:05:03 AM • Jabra Bluetooth... • Answered on Apr 07, 2013
0answers
2answers
MANUAL FOR JABRA HFS001
I can't pair my Jabra HFS001 with my HP iPAQ 900
12/20/2012 6:04:01 PM • Jabra Bluetooth... • Answered on Dec 20, 2012
How do I pair my
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
1/5/2011 12:00:13 AM • Jabra Bluetooth... • Answered on Jan 05, 2011
Will not pair with my
why will it not pair with my evo phone
1/3/2011 10:36:44 PM • Jabra Bluetooth... • Answered on Jan 03, 2011
Need to put jabra hsf001 into pairing mode
I NEED HELP WITH THIUE JABRA HFS001
1/3/2011 10:36:09 PM • Jabra Bluetooth... • Answered on Jan 03, 2011
How do I connect or pair my jabra model hfsoo1 to
how do i connect or pair my jabra model hfs001 to my phone
9/30/2010 8:46:44 PM • Jabra Bluetooth... • Answered on Sep 30, 2010
Jabra hfs001 is not connecting
MY JABRA CONNECTS BUT I HAVE NO VOLUME I HAVE A
T-MOBILE PHONE. I RESET THE JABRA I TURN UP THE VOLUME ON MY PHONE NOTHING
9/28/2010 4:40:10 PM • Jabra Bluetooth... • Answered on Sep 28, 2010
Jabra HFS001 I can't connect with my iphone 4?
MY JABRA CONNECTS BUT NO VOLUME TRIED TURNING UP PHONE TRIED RESETTING JABRA ALSO
9/28/2010 4:36:52 PM • Jabra Bluetooth... • Answered on Sep 28, 2010
Cant Pair
Try asking your questions again in the proper category since the expertise in this area is tripods and cameras, not luggage. If you ended up in tripods after starting in luggage, contact the FixYa staff to correct the problem. The other categories experts will be much better at answering your specific problem than the photo guys.
6/25/2010 6:55:12 AM • Jabra Bluetooth... • Answered on Jun 25, 2010
Need to pair jabra Bluetooth car kit with mobile
You need to put the Car Kit in pairing mode, usually done by starting with the power off and holding the power button till the light flashed Red and Blue or solid Blue.
Then search for the car kit from your phone. Once found pair using pin code (pass key) 0000 or 1111 or 1234.
5/5/2010 7:15:43 PM • Jabra Bluetooth... • Answered on May 05, 2010
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
Jabra Bluetooth Car Kit with Night Driving Mode Tripod Logo
28 questions posted
Top Jabra Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Jabra Photography Expert? Answer questions, earn points and help others
View Most Popular
Jabra Photography
  • Jabra Photography
Most Popular Question
manual jabra hfs001
  • Photography
