20 Most Recent Yard Machines 28" Two-Stage Snowthrower Questions & Answers
2answers
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
3/10/2015 1:25:38 PM • Yard Machines... • Answered on Mar 10, 2015
Electric Maztang mt 968 auger wont run
the motor runs but the auger does not , if so the bolt snapped in half from hitting something that you should have not hit , this is a normal thing so as to not blow up the engine , it is a safety feature in all snow blowers , just get the right bolt or make one grind it down to where it will break easy but will work the auger , they sell them on ebay for a couple bucks but I make mine
2/3/2015 6:32:34 PM • Yard Machines... • Answered on Feb 03, 2015
Yard machine snowblower wheels seem to be locked up
if its a old one then the drive wheel is always egaged. due to bushings worn out on the axle
12/18/2013 2:11:00 PM • Yard Machines... • Answered on Dec 18, 2013
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom can also take off belt guard (2bolts) and check to be sure belts are on correctly
12/18/2013 1:50:12 PM • Yard Machines... • Answered on Dec 18, 2013
Does yard machine tiller model 21A-395A129 use gear oil
Yes. 80-90w gear oil.
9/23/2021 12:13:32 AM • Yard Machines... • Answered on Sep 23, 2021
2answers
Model 13an771g729. What is valve clearance?
That model number isn't coming up. The correct search query is MAKE (MTD?) model "valve clearance" as typed. All questions here must have full make and model. You can also google make model manual it's here, but no valve clearance https://usermanual.wiki/MTD/13AN771G729.195737860 Here are all the Briggs and Stratton valve clearances https://outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp https://www.google.com/search?q=13an771g729.+What+is+valve+clearance%3F ..
5/5/2021 9:40:04 PM • Yard Machines... • Answered on May 05, 2021
3answers
Need manaul, diagram and parts list for a Dynamark
Call Oscar Wilson at 1-800-849-1297. The will not be able to give you a manual but they have them on microfiche and they can probably look them up if you describe what you need. I hope this helps!
4/27/2021 12:27:30 PM • Yard Machines... • Answered on Apr 27, 2021
My Yard Machines 675 ex won't restart when hot - Briggs and Stratton motor
Could be failing ignition module or needs valve lash adjustment... periodic requirement for BS OHV engines.
10/27/2019 4:06:57 PM • Yard Machines... • Answered on Oct 27, 2019
3answers
My countax 300 will not start there is nothing
First check the safety switch under seat is working by bridging the gap.Try the same with the safety switch on hand brake.Check fuse hasn't blown.Check spark plug is intact and cable is correctly fitted.Check in line fuel filter.Ensure battery is fully charged, a drop in output will result in not starting.Hope this resolves the problem.Gareth
9/1/2019 6:26:54 AM • Yard Machines... • Answered on Sep 01, 2019
Y4700 EC Remove the spool assembly
there should be a place right below the spool to either put a screwdriver or a wrench in and you will turn the spool like a nut to get it off
5/27/2019 12:29:50 AM • Yard Machines... • Answered on May 27, 2019
The wiring diagram yard machine 660 thru 679. I took solenoid off without marking the wires now I don't know which wire's go to what on the solenoid
There may be a manual showing the wires at this web site. I FOUND THIS WEB SITE that I think will help you with this question and a lot more. Since this web site will have access to many different vehicles I hope you do not feel like I am lazy by just passing along the web site instead of giving you the exact information you asked for. Go to this site to find a manual to help you. https://www.browsemanuals.co/lander_zrk65_test14.html?t1=1535071160&t2=65192170713&t3=kwd-28425796&gclid=EAIaIQobChMI-oybpN624AIVwdVkCh2GtguWEAEYASAAEgJ9yvD_BwE
2/22/2019 7:07:22 PM • Yard Machines... • Answered on Feb 22, 2019
Mower belt replacement
Parts Tree Repair Clinic may have a video
2/9/2018 2:22:44 PM • Yard Machines... • Answered on Feb 09, 2018
Yard machines manual
try PartsTree.com
2/9/2018 2:14:02 PM • Yard Machines... • Answered on Feb 09, 2018
I have a yard machine 5hp 22" snow blower. The
TRY PUTTING SOME SEA FOAM IN YOUR GAS AND LET IT RUN AWHILE MAY HELP.
12/25/2017 4:49:57 PM • Yard Machines... • Answered on Dec 25, 2017
I have a Yard Machine 42" cut 17 hp lawn tractor.
Take the belt to parts house and get a smaller belt. The old belt was stretch out of length. If you match the old to the new you just get a new version of the old stretched out belt
12/25/2017 4:08:07 PM • Yard Machines... • Answered on Dec 25, 2017
Yard Machines 28" Two-Stage Snowthrower Logo
4 questions posted
Top Yard Machines Garden Experts
john h
Jay Finke
Jay Finke
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Garden
Most Popular Question
mtd yardmachine snow blower 305 cc auger
  • Garden
