20 Most Recent
Tivoli SongBook Clock Radio Questions & Answers
My black Tivoli Songbook case
Hi Jodi:
Same with both of mine. I used solution of vinegar and water, about 50/50. It seems the "rubbery" texture is now gone, but the terrible sticky is gone also. The solution did not remove any of the lettering or numbers.
Moose in Phoenix
Tivoli radio sticky case
I have the yellow songbook and it was so sticky and dirty after only a couple of years. I only use it inside, so I removed the sticky coating with nail polish remover and a ton of cotton balls. It worked really well on the yellow one - the finish is a little dull so it matches how it looked when it was new. And it's so clean now!
Tivoli Audio Model Two OFF - FM - AM - AUX Switch
It sounds like there may be a problem with the switch or the connections between the switch and the circuit board. Here are a few troubleshooting steps you can try:
Clean the switch contacts: Over time, the contacts in the switch can become dirty or corroded, leading to poor or intermittent connections. You can try cleaning the switch contacts with a small amount of contact cleaner or rubbing alcohol on a cotton swab. Be sure to unplug the radio from the power outlet before attempting any cleaning.
Check the connections: The switch may not be making a good connection with the circuit board, or there may be a loose wire or solder joint. You can try opening up the radio (if you're comfortable doing so) and checking the connections between the switch and the board. Look for any loose wires or solder joints, and gently re-seat or re-solder them if necessary.
Replace the switch: If cleaning and checking the connections doesn't solve the problem, the switch itself may be faulty and need to be replaced. You can contact Tivoli Audio customer support to order a replacement switch and get instructions on how to install it.
