20 Most Recent
Whirlpool GU2300XTS 24 in Builtin Dishwasher Questions & Answers
Turn dishwasher on . the water loads in and then
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address
[email protected] with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
4/25/2017 4:04:56 PM •
Whirlpool...
Answered
on Apr 25, 2017
Whirlpool dishwasher wont turn on
first thing to do is to check if u have power to washer. check to make sure the breaker in your main electric panel is not tripped. If it is ok then take front cover off kick panel make sure that the wires running to the washer are not loose. be sure to turn off the breaker first. IF they are tight then turn on braker and check wires at washer connection with volt meter to see if u have power.
4/11/2014 2:20:04 AM •
Whirlpool...
Answered
on Apr 11, 2014
Wont start
First thing to check is that the float isn't lifted:
https://farm2.staticflickr.com/1030/732207252_6eda800fbc_z.jpg?zz=1
This pic shows a spoon lodged under the float, holding it up, but even tilted to one side could do this.
With the float up, it signals to the washer that it is at it's full limit of water, and won't allow the pump to introduce more water, so it won't start.
Just locate the float, lift it, and see if it drops back down on its own.
4/11/2014 1:42:28 AM •
Whirlpool...
Answered
on Apr 11, 2014
Residue left on dishes And glassware not properly
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
8/13/2011 1:18:17 AM •
Whirlpool...
Answered
on Aug 13, 2011
My dishwasher is not cleaning properly. The soap
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
mmnxv
9/29/2010 3:31:35 PM •
Whirlpool...
Answered
on Sep 29, 2010
Wonderful Whirlpool Washus Interuptus!
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
8/26/2023 5:52:50 PM •
Whirlpool...
Answered
on Aug 26, 2023
