20 Most Recent
Samsung Behold II SGH-t939 Smartphone Questions & Answers
How do i unLock my samsung behold 2
first of all u need a unlock code
It is possible to get a free unlock code for your Samsung Behold 2 T939 if you call up your phone carrier and request one. If they will not give you one, you will need to use an unlock code generator or possibly pay for one from an online vendor. However you decide to go about getting an your Behold 2’s unlock code you will first need your mobile phone’s IMEI number. Your IMEI number is unique to your Samsung T939 and will be used to directly calculate your unlocking code. You can find your IMEI number simply by typing *#06# and hitting enter.
Once you have an unlock code you can use the free unlock instructions below. If you are looking to unlock the Samsung Behold T919 and not the Behold 2, then go here.
1. Power on your Samsung mobile phone without the SIM card in.
2. Type #7465625*638*
3. Enter your Samsung unlock code
4. Type #
5. If worked, phone should say “Network Lock Deactivated”
6. Your Samsung phone may automatically reboot.
How to unlock PUK code
Please contact your service provider for a PUK code. Only they can provide that to you.
Black screen phone turns on but screen stays black why
How long have you had the phone?
Sounds like hardware failure.
If its still under warranty you could take it in for repair.
try turning phone on while plugged into the charger. Does this make any difference?
Try charging using a different charger. The fault could be battery or charger related. Might have just enough juice to start the phone but not the screen
hope this helps
I need code to unlock my sim
Is your sim locked with any particular network?In that case you can unlock it using the unique unlock code from
Theunlockarena.com and remove the network restriction.You need to specify the country,locked network and based on the availability get the unlock code along with free unlock instructions for your Samsung Behold 2 SGH T939.
How to add internet settings(APN)
or anyone wanting to know how to change their APN settings for future reference here it is:on the keypad type *#87927# and wait until the APN setting pops up. click the APN available.then change these settings. name : t-mobile us 310 260 ----> name : simpleAPN : epc.tmobile.com ----> APN : simpleproxy : not set ----> proxy : 216.155.165.050port : not set ----> port : 8080username <leave blank>password <leave blank>server <leave blank>mmsc <don't change>mms proxy : not set ----> mms proxy : 216.155.165.050mms port : not set ----> mms port : 8080mcc <don't change>mnc <don't change>apn type <don't change>authentification type <don't change>after that just back out and give it a few minutes. as long as you have the data plan your 3g icon should show up ready to go.
I need to sim network unlock pin for my samsung
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
I WANT TO UNLOCK
sir if you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.................
I NEED A SIM NETWORK UNLOCK CODE FOR MY SAMSUNG
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
How to enable mms text on an unlock Samsung behold
if you havent got the right configuration settings on your phone already then you need to contact your service provider and they wiil send you the configuation settings,then store them on your phone and you should be able to send them
