20 Most Recent
Eclipse CLD2 MP3 Player Questions & Answers
I download music and wont play
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you haveconnected the USB cable to the MP3 player and the computer.You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Another question
How do i know what songs are on
Connect it to a PC and view the track list. And you will see the song list provided you have tagged them in the first place.Downloaded music are usually tagged but when you rip your own MP3 music the titles have to be manually fed into the computer.
I dont know how to
This is simply because the Eclipse MP3 player does not read .AVI formatted videos. The videos must be in .AMV format. A good way to convert your .AVI videos into .AMV is to use FreeAMVConverter located at the following link.
http://www.amvvideoconverter.net/. You can use this to convert your videos to .AMV format and then they should work.
Hope this helped,
NathanTaylor
How do i delete songs from my eclipse mp3
Plug the device into the computer. The pop-up window will open. Select view the files. Select the song you want to delete, right click, select delete. That will delete the song.
Eclipse MP3 Player- Wont charge. I plug it in and
People on other posts said to get a wall charger and that'll work. We
looked for one, but couldn't find one. We ended up using a usb camera
upload cord that had the same connector. It charged just fine after
that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty
universal.
I have downloaded music into
You have to follow both steps on the instruction manual. When you first plug it into your computer it prompts you to name it. Then sync the music files off of Windows Media player..then you must do the second part where it explains about copying and pasting the music to it..this link opens the pdf manual that explains it just like the directions that came with it. http://www.eclipsemp3.com/CLD2manual.pdf
I think people are getting confused and thinking that step is only suppose to be used if they can't sync it ..but you actually have to do that part too or the files won't go onto the MP3 player.
Eclipse mp3 player says "no file"
I had the same problem. I think most files that itunes uses are in a .m4a format. The eclipse mp3 player will need all the music files in an .mp3 format. The eclipse actually has a "software" folder that includes the "replay converter" that will convert these files for you - or you can download any number of freeware that will convert the files as well. Once I converted those files, my eclipse played everything. Prior to that - even though I had synced everything with my Windows Media player, I was getting the "No Files" message. Good Luck!
Hi dominguez8...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
What is format error' ?
The song you are trying to play on the MP3 player is probably not MP3 , or it is a format that the MP3 player cannot read.
How to set up an eclipse fit clip plus mp3 8GB and how to download music without using iTunes?
To use it without iTunes, you can just go to any free music download site and download and save music. Then go to your files and drag all of the music you want on your player into teh player, adn into the MUSIC folder. Then eject the player. It should be able to play the mucic. For the free download site I reccomend www.mp3juices.com but that's just me. Hope this works for your music problem!
Could a driver problem cause a mp3 player not to be read by your laptop?
Yes, the drivers have to be installed in order for the computer to identify any device attached to it.
If your laptop is a windows machine you can check whether drivers are installed by entering device managerand checking whether there are any items under the "other devices" drop down. The exclamation mark on that tab indicates that the drivers are not installed.
If your mp3 is attached to the computer and not listed there it will be in need of the appropriate drivers
