Before working on electrical equipment please observe general safety.
Make sure the work area is clean and dry.
This task is recommend for DIY'er with electrical experience only.
Difficulty scale is 7 out of 10.
Inspect the 15 or 20 amp circuit breaker on the fuse panel.
Turn OFF the circuit break before inspecting the hood unit.
There are three wires connected to the household circuit.
Make use all three wires are secure.
Here are part of the instruction from the install manual.
You can view the entire manual HERE
• Connect white leads to branch circuit white
lead.
• Connect black leads to branch circuit black
lead.
• Connect green/yellow leads to branch
circuit green or bare ground lead.
• Secure all connections with wire nuts on
each electrical connector.
• Push wires into junction box and replace
cover. Be sure wires are not pinched.
The install may install the optional in-line fuse on HOT lead.
The standard color is BLACK on newer building.
One older building it will be RED.
Inspect / Replace the in-line fuse with the same value (if equipped)
Check fan for free movement
Change the filter element is it in service over 30 hours.
Double check work area.
Power on the circuit breaker to check operation.
Reference
GE Answer
Center®
800.626.2000
Whatever your question about any Monogram major appliance, GE Answer Center®
information service is available to help. Your call-and your question-will be answered
promptly and courteously. And you can call any time. GE Answer Center®
service is open
24 hours a day, 7 days a week.
