How do i delete music
Hi, OK, here is what to do, you hook up to your PC via the USB cable, that should have come with your player, now when you do this Windows will "pick it up" and install a Mass Storage driver, this then will make the Player look like a HDD. Now it should be visible in MY Computer. Find the "Drive" in MC, and then double click on the icon, it will now open up, just like the directories in your PC. Now just teat it like you would any other Drive, simply navigate to wherever the file are that you want to work with.delete, and simply click on the files and select, Delete, and do so, if you want to delete forever, hold the shift key down while Clicking on Delete.,or just delete the file, and then it will go into the recycle bin, trash, should you wish to recover it? If you wish to delete multiple files you can select with the mouse and holding down the SHIFT key, you can select contiguous files, if you wish to do random order files all at once, simply hold down the CTRL key at the time of selection.select what you want and then select delete.
you can also put whatever you want using Copy/Paste/Cut just as you would any other drive.
