20 Most Recent Mitsubishi WD65737 65" DLP TV Questions & Answers
If the bulb is burned out will that cause no sound
sounds like screen gone tv repair man best bet have you got set on mute
10/25/2017 10:34:53 AM • Mitsubishi... • Answered on Oct 25, 2017
Mitsubishi Lamp wireing
It doesnt matter. Its an AC lamp. Either terminal is fine. I know this is an old posting but it may help someone else.
9/21/2016 7:55:27 PM • Mitsubishi... • Answered on Sep 21, 2016
2answers
I have a mistubishi tv model wd-65737 with bad picture. I replaced the video chip and color wheel but that didn't work....is it possibly that dmd board?..thx
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
9/12/2016 12:10:40 PM • Mitsubishi... • Answered on Sep 12, 2016
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
3/24/2016 4:50:54 PM • Mitsubishi... • Answered on Mar 24, 2016
Black bar on dlp tv.how do I fix this?
Sounds like a connection problem between board and DLP chip. The BGA connection which connects the DLP chip to the board, or the flex connector may be bad, causing the row and column section to not activate the micro-mirrors on the DLP chip. Not an easy fix. Regards.
1/5/2016 4:45:02 PM • Mitsubishi... • Answered on Jan 05, 2016
I have sound but no picture. After several seconds the sound shuts off and red light comes back on. Did an error check and green light keeps flashing 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience.
12/13/2015 2:14:34 AM • Mitsubishi... • Answered on Dec 13, 2015
Why is picture 1/3 down from top and 3" in on right side is a little darker?
Did you move or bump the TV? That can cause misalignment. Did anyone fool with the setup? Get the manual and run through that again. Did you change input source (IE new DVD player, etc)? There is a setup (usually in menu) for slight adjustments to picture in most TVs, like on computer screens adjustments if you ever have done that. RTFM
10/26/2015 3:44:17 PM • Mitsubishi... • Answered on Oct 26, 2015
When i press power button
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
10/8/2015 2:13:31 PM • Mitsubishi... • Answered on Oct 08, 2015
Two white dots appeared on screen- one blinks and one does not. Picture is currently good
DLP/DMD chip is failing. you need a new DLP chip for that model TV. the pixels are sticking. it will get worse as time progresses.
3/2/2015 6:29:17 PM • Mitsubishi... • Answered on Mar 02, 2015
How do I fix the color? We replaced the dlp chip and since then we see blue lips and brown grass/trees.
Your color wheel is not calibrated properly. It needs to be re-aligned with the colorwheel. That will require access to the service menu. Service manual eprom result list ElektroTanya Service manuals and repair... Here is the service manual which will show you how to re-align the color wheel.
3/2/2015 6:16:22 PM • Mitsubishi... • Answered on Mar 02, 2015
Replace chip for white dots now have two black bar top and bottom model wd65735
Probably ok. Check the picture ratio or format settings to see if the bars go away when aspect ratio is right setting.
2/11/2015 6:06:30 AM • Mitsubishi... • Answered on Feb 11, 2015
2answers
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
1/3/2015 5:54:49 PM • Mitsubishi... • Answered on Jan 03, 2015
I have white dots on the screen of my 65'' mitsubishi what is wrong ?
you have a bad DMD chip call Mitsubishi. they will send one to a servicer at no cost you only pay for labor
10/13/2014 12:49:46 PM • Mitsubishi... • Answered on Oct 13, 2014
Mitsubishi WD65737 65" DLP TV Logo
174 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
tv turned itself off started blinking
  • Televison & Video
