20 Most Recent Nokia 6720 Classic Cell Phone Questions & Answers
0answers
Sim card rejected
call 198 customer care.
1/24/2014 9:10:02 AM • Nokia 6720... • Answered on Jan 24, 2014
0answers
Fat battery
Be the first to answer 11/4/2013 1:40:52 PM • Nokia 6720... • Posted on Nov 04, 2013Be the first to answer
Restore factory settings
RESETTING PHONE NOKIA:Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380# This function apparently works on almost all nokia mobile phonesHARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset •Enter the code: *#7370# and press Yes to confirm initialization. •Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) •To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: •on/off + * + 3 •Before making a Hard reset better backup all your important information: contacts , memo...etcFORMAT NOKIA:While my phone if power ON. Press the *7780# code, this code is usually used for the N60 series phone but this code is not working for nokia 5310. And I tried also another procedure again by doing this process:Your phone must be power off, press the "*" + "3? + "green call key" but nothings happen again I haven't format my phone.What should I do for this phone, this is able to recognize in the computer and cannot format to hard boot formatting.My last choice is to find a flash utility cable suits in my phone and the software to re-program it and putting some IMEI codes.
10/9/2013 9:06:43 AM • Nokia 6720... • Answered on Oct 09, 2013
I m from uzbekistan, now i m in turkey my phone nokia 6720 blocked what should i do to unlock????????
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
1/28/2013 5:38:45 AM • Nokia 6720... • Answered on Jan 28, 2013
Nokia 6720c signyal problem
Hello My Friend:::First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
12/29/2012 7:02:23 AM • Nokia 6720... • Answered on Dec 29, 2012
2answers
The key bottom not working and number 1,4,7
REMOVE UR KEYPAD AND BYE NEW KEYPAD
11/11/2012 12:57:43 AM • Nokia 6720... • Answered on Nov 11, 2012
2answers
I cant seem to send
Hard reset your phone. This will delete all the content of your phone so remove your memory card before resetting your phone. On the home screen type *#7370# .
6/12/2012 1:58:54 PM • Nokia 6720... • Answered on Jun 12, 2012
2answers
My nokia 6720 classic wont start?
try to change the battery first then if still not working the issue is with the cellphone itself
5/21/2012 4:18:14 PM • Nokia 6720... • Answered on May 21, 2012
2answers
My nokia 6720c keypad not
My Dear Your Phone Keypad IC Fault So Please change Keypad IC
And Keypad Problem will Solved
5/18/2012 4:07:31 PM • Nokia 6720... • Answered on May 18, 2012
0answers
How do you take the cover off to get to the lcd
Hello and Welcome to FixYa!
I can give you the Service Manual, in which you can have the overall exploded view, step by step disassembly.
You can click here to download the Manual.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
2/21/2012 3:36:51 AM • Nokia 6720... • Answered on Feb 21, 2012
6720 nokia. message to delete memory from C: Phone memory
First Download and Install Nokia PC Suite - Free software downloads and software reviews - CNET Download.com.connect your phone via usb by selecting Pc suite/Ovi suite.After this "Initialising synchronisation" is finished open Pc suite click to the Message Icon.Then you will see another interface click once to the particular message which you wish to delete.And delete it by clicking the delete icon, which is shown in the image 2_16_2012_11_06_24_am.jpg
2/18/2012 9:59:03 AM • Nokia 6720... • Answered on Feb 18, 2012
Ive got a nokia 6720 and I need an unlock code or a way of unlocking it.
Hi,It is so simple to Unlock your Nokia 6720 .go this site order your Nokia Imei Unlock Code and get your imei unlock code.this site is offer best price.and guide you to how to enter your Nokia Imei Unlock Code.customer support is excellent. i hope t
2/14/2012 8:16:01 AM • Nokia 6720... • Answered on Feb 14, 2012
Battery showing charged,but when i go to use shows battery low
your battery is damaged. better you purchase a new one.
1/8/2012 5:15:45 AM • Nokia 6720... • Answered on Jan 08, 2012
Unable to connect my nokia 6720 classic via
install the latest version so as to have the best supporting driversthen check it outmake sure your bluetooth dongle works fine
11/10/2011 2:33:15 PM • Nokia 6720... • Answered on Nov 10, 2011
Nokia 6720 Classic Cell Phone Logo
113 questions posted
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
Classic Nokia
  • Classic Nokia
Most Popular Question
replace lcd screen
  • Cell Phones
