20 Most Recent
LG GW525 Cell Phone Questions & Answers
How do I get to my voicemail?
You would ring a number supplied by your mobile provider, and this accesses your messages which are stored on their server. Where I am, for instance, on Vodafone, I connect to 121.
LG GW525 Battery Prolonging
hi , your phone usage will determine your battery life . turn your display brightness down to 3 or so. max charge time should be 2h30 min
I need puk code for lg gw525
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
How can i update my
me can't receive the sms and send as well and customer care don't have any support just saying to go to showroom/ visit to LG service centre.
Cant delete old numbers from lg gw525
Try doing a hard reset, it should be under settings and for the security code it should be 12345, 0000 or the last four of your number.
www.usedcellphoneshop.com
I need a puk code for a lg
PUK CodePUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
I cant set my profiles.
do the factory settings or hard reset with this code 2945#*# and select factory reset. this second method will delete your data so first make backup.
