20 Most Recent
Xante AW 1200 Laser Printer Questions & Answers
Unable to get Xante printer to work
When I send a job to the printer via Ethernet, nothing happens on the printer. I only get a solid red light. Why?
This is an indication of a media size mismatch. Make sure that the correct media size is set on the tray to which you are printing, and try the job again.
(from
http://www.xante.com/support/aw1200/)
John
(Xante ASA)
PAPER CURLS INSIDE PRINTER AND WILL NOT FEED INTO
Some things that affect laser printer curl :
(1) the side of paper printed
(2) long vs. short grain paper
(3)
its moisture content
(4) basis weight
(5) long and short edge
feed
(6) paper source including mill, paper machine and manufacturing
conditions (for example, Xerox 4024DP® paper brand is made in several
mills but the curl properties from each source are not exactly the same.
Sheet structure makes a difference.
(7) non-paper effects like paper
path, bending applied to the paper in its travel, including in the nip
itself (fuser roll) and temperature of fuser and backup rolls.
All
of the above should be considered as possible variables. For the small
volume paper user trying different papers is probably the best approach.
Red and Green lights both stay on AW1200 and now
The temperature in my office was 38 degrees yesterday. After I turned the heat up the printer "dethawed" and started working normally. I believe the problem was environmentally induced and therefore solved with the more moderate temperature. Thank you for your reply.
Xante 1200, paper jam front.
PROBLEM: Paper Jam.
XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront.
If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper!
This printer is problem free. It has given us the best service for many years.
Michael J. Frangos,
Baltimore, Md.
Xante ilumina 502 network menu lost
If the network menu is lost on your Xante Ilumina 502 printer, it may be possible to restore it by resetting the printer's network settings. Here are the general steps to reset the network settings on the Xante Ilumina 502:
- Power off the printer.
- Locate the network card on the back of the printer.
- Press and hold the small button on the network card for 10-15 seconds. This will reset the network card to its default settings.
- Power on the printer.
- Press the "Menu" button on the printer's control panel.
- Use the arrow keys to navigate to the "Network" menu.
- Select "TCP/IP" and then "DHCP" to ensure that the printer is configured to obtain an IP address automatically from your network.
- If your network requires a static IP address, you can manually configure the IP address and other network settings in the "TCP/IP" menu.
- Save your changes and exit the menu.
