20 Most Recent
Microsoft Windows 7 Ultimate for PC Questions & Answers
Why my windows explorer does not respond
Try this:
Reboot the computer. As soon as the "Starting Windows" screen comes up, hold down the Power Button until the computer shuts down. Now, restart the computer, and a Windows Tools screen should pop up. Choose Startup Repair (recommended). Be patient and follow the directions. Good luck.
12/16/2017 11:26:41 AM •
Microsoft...
Answered
on Dec 16, 2017
I dont have a genuine windows 7 key gen. Can I
To obtain a serial key for Windows you need to purchase Windows 7. The only other way you can possibly get a key is to use a crack program or to download a cracked copy of Windows. You can use a program called Utorrent to download torrent files. You may find a torrent file for what you need on the site www.piratebay.org, however, beware it may be illegal to download Windows without purchasing.
-G33k
5/10/2016 6:50:17 AM •
Microsoft...
Answered
on May 10, 2016
Remove all windows updates
Updates from Microsoft generally do not cause printers to stop working.
What kind of printer is it?
Usually if you clear the printer from the device list (delete it) and reinstall the printer again, this is a quick way of getting things going. What changes have been made since the printer stopped working on your PC or with the printer?
1/3/2016 2:31:09 AM •
Microsoft...
Answered
on Jan 03, 2016
Splitcam will not close
Run your anti malware software to find any viruses or pups.
Malwarebytes does a good job for me.
8/18/2014 3:01:47 AM •
Microsoft...
Answered
on Aug 18, 2014
How do i change my keyboard from typing backwards
Go to control panel; keyboard, hardware. Check settings. Check that the keyboard you are working on is ticked. This should say: The device is working properly. Note the port. You can try changing ports (plug in); Click Troubleshoot for more help. If not, can you find the disk for your keyboard? Re install and note settings it chooses. Check your computer with Malwarebytes for pups and viruses.
8/18/2014 2:35:06 AM •
Microsoft...
Answered
on Aug 18, 2014
Fx 2175 change page setting printer
That's pretty wide paper, perhaps you're printing a PDF that somehow came out that size (and in print settings you haven't told it what size to adapt to?)
8/4/2014 5:33:12 AM •
Microsoft...
Answered
on Aug 04, 2014
Why cant i install windows updates-it shows error0x80040609
Uninstall windows Live Essentials
Below are the steps on how to uninstall Windows Live Essentials via CMD line parameter.
a. Go to Start ->All Programs ->Accessories
b. Right click onCommand Promptand select Run as Administrator
c. Run the following commands to uninstall Windows Live Essentials:
· (64 bit) "c:\program files (x86)\windows live\installer\wlarp.exe" /cleanup:all /q
· (32 bit) "c:\program files\windows live\installer\wlarp.exe" /cleanup:all /q
d. A dialog box shows status until uninstallation has completed
The uninstaller for Windows Live Essentials 2011 can also be downloaded
8/2/2014 6:24:06 AM •
Microsoft...
Answered
on Aug 02, 2014
How to speed up your PC?
When your use you pc additional applcations running in background , temporary files and registary errors make you pc slow. Download CCleaner install install it and run the clean tool at least once a week your will see the changing.
CCleaner DreamSoft
