20 Most Recent
3Com Baseline Switch 2024 24-Port (3C16471B) Questions & Answers
3com Switch Intermittently Losing Connection.
this could be a problem with the second switch unit. what happens if you connect a pc to this cable, is that intermittent, if so, that is your problem. try fault finding with a LAN cable tester to see if there's any issue with the link cable.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
