20 Most Recent
Intel EXPI931CTBLK Gigabit CT Desktop Adapter Card - PCIe Network Adapter Questions & Answers
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
How can I troubleshoot a slow computer performance?
The end part of your question makes it sound like an advert.Download and run the Free version of CCleaner. Remove TSR (terminate and stay resident) programs on start up. These are the programs that run in the background.Download CCleaner 6 For Free - Make Your PC Faster & Saferccleaner.comhttps://www.ccleaner.comClean Temporary Files, Optimize & Speed Up Your Computer. Download Now. The No. 1 Tool for Cleaning Your PC. Download CCleaner now. Browse Solutions. View Products. Multiple Payment Options...
The Green led on the motherboard is ON, and the Intel D915gav won't turn on even though it was working well the day before.
There are several possible reasons why your Intel D915gav motherboard won't turn on, even though the green LED on the motherboard is on. Here are some troubleshooting steps you can try:
- Check the power supply: Make sure the power supply is turned on and connected properly to the motherboard. Verify that the power cable is securely plugged into the wall socket or power strip and into the power supply unit. Also, check if the power supply is providing the correct voltage to the motherboard.
- Inspect the RAM: Check if the RAM is seated properly in the slots. Remove the RAM and re-insert it, ensuring it's seated firmly in place. You can also try booting with one RAM stick at a time to see if one of them is faulty.
- Check for loose connections: Check all cables, connectors, and wires to ensure they are properly seated and secured. Make sure there are no loose wires, frayed cables, or damaged components.
- Test the power button: If the power button on your computer is not working, the motherboard won't turn on. Try connecting the power button pins directly to the motherboard to see if it turns on.
- Clear the CMOS: Try clearing the CMOS memory to reset the BIOS settings. This is done by removing the CMOS battery for a few minutes, then re-inserting it and restarting the computer.
- Check the CPU: Make sure the CPU is seated correctly in the socket and that there is no thermal paste residue between the CPU and the heatsink. If there is, clean it off and reapply fresh thermal paste.
If none of these steps resolve the issue, it's possible that the motherboard or another component has failed and may need to be replaced.
Hovedkort: Lite-On Tech. 08FCH (mPGA 478)
Det ser ut til at hovedkortet ditt er ganske gammelt og ikke lenger st?ttes av produsenten, og det kan v?re utfordrende ? finne drivere for det.
Du kan pr?ve ? s?ke etter drivere p? Lite-On Techs nettsted eller p? produsentens nettsted for hver av de komponentene du nevner (Multimedia Sound Controller og Intel 82865G Graphics Controller).
Alternativt kan du pr?ve ? bruke en driveroppdateringsprogramvare som kan skanne systemet ditt for ? finne og laste ned de manglende driverne automatisk. Imidlertid b?r du v?re forsiktig n?r du laster ned og installerer driveroppdateringer fra tredjeparts nettsteder, da de kan v?re up?litelige eller inneholde skadelig programvare.
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain
operating systems and hardware, so refer to your player's documentation to
ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you
have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player
to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with
your MP4 player.
Restarting your PC resets non-functioning USB ports, which
may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure
you install them.
Try connecting your player to another PC to see if the new
PC recognizes it.
If it does, chances are your computer does not support the
hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to
recognize it.
Resetting your player varies depending on the manufacturer
and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable
to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
How to connect OLD hard disk 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439
to intel core2 duo? MY SECRET PC MODEL NOT TOLD.
CORE2 NOT CORE CORE 2 IS 2006 TECH.(first)A 13 year old PATA drive, reviews 2005 yah a relic. No PC model told ,desktop or laptop? 2006?intel only mobo ?. not told|I will not cover, mobo with via or sis or Nforce chips with IDE support. just intels. and not Marvell chips on the mobo, or the like. 80GB AT HDD ExcelStor Jupiter Callisto J880 K2B5P3H IDE ID13439it just plugs into a IDE (PATA) 40pin port. it is NOT A SATA drive. ( i BET IT IS BAD)there are only 3 ways to use any PATA (ata ide)DRIVEA MOBO WITH THE 40 PIN PATA PORT.THERE.OR AND PCI ADAPTER PATA THERE. (WITH BOOT ROM IF NEEDED)OR A SATA TO PATA DIRECT ADAPTERTHAT IS ALL There is. (got the last pata drive on earth not dead, is that it?the last real intel mobo with PATA ports is ICH7and is CORE2. P31 +ICH7 chip set.?(yes some PCs had Marvell chips on board to add IDEto ICH8 PCs that intel ended, IDE forever Ich7 south bridge has old IDE pataICH8 mobile has IDE BUT NOT ON desktops and others.ICH9 may 2007 ends IDE in the intels chips forever..NO PC MODEL TOLD OR IF DESKTOP WHAT MOBO IS THERE.IF EVEN IF A SERVER, NOT TOLD.IT JUST PLUGS-IN, SET JUMPER TO SLAVE IS 2ND DRIVE.NOT TOLD IF IS BOOT DRIVE. ETHER.
