20 Most Recent Intel DG41RQ Motherboard & Core 2 Duo E7500 Processor Bundle (INTEL DG41RQ MB & CORE 2 DUO ...) Questions & Answers
I want to purchase a
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128433
quadcore
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115210
dualcore
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115054
9/13/2018 1:31:10 PM • Intel DG41RQ... • Answered on Sep 13, 2018
I have intel dg41 rq
Check the fans on the motherboard, are they all working? Have you cleaned out the fans and heatsinks ? Using compressed air, or even the blower end of a vacuum cleaner blow out the dust in the fans and the cooling fins of any large heat sinks, like the one over the processor. It sounds like the machine is overheating, the dust is probably preventing air from circulating around the heat sink fins,
11/6/2017 2:35:17 AM • Intel DG41RQ... • Answered on Nov 06, 2017
3answers
Computer doesn't boot. Get 51 in the start screen
Error 51 means there are problems allocating resources to PCI bus.
To solve this you would have access the BIOS and set it to its default settings. Reboot the computer and the error should be gone.
If it's not then take out any cards that maybe in the PCI slots on the motherboard as you may have a faulty PCI card in the computer.
Regards.
2/20/2016 10:58:44 AM • Intel DG41RQ... • Answered on Feb 20, 2016
Azrq030002lr-aa-e54511-205
remove the RAM clean it and fix it again...
1/22/2016 6:44:33 AM • Intel DG41RQ... • Answered on Jan 22, 2016
DG41RQ MOTHERBOARD DOES NOT RECONIZE HARD DRIVE
tried using that harddisk on other Motherboard??? try that once. if it works then ur motherboard is done or vice versa
5/7/2014 7:51:50 PM • Intel DG41RQ... • Answered on May 07, 2014
Hi, I have a Intel DG41RQ mobo with short circuit
i have exact issue, i found MOSFET bad it is near processor and has markig (Q36) It is N-cnannel mosfet. I order new and waiting to recive it.
11/1/2013 9:40:39 PM • Intel DG41RQ... • Answered on Nov 01, 2013
2answers
I have intel core 2
Yes, perfectly fine. read this:
http://downloadmirror.intel.com/17250/eng/DG41RQ_TechProdSpec.pdf
6/7/2013 8:13:45 AM • Intel DG41RQ... • Answered on Jun 07, 2013
Ps2 scokets not working
If it is both of the P/S2 sockets, you may need to flash the BIOS. But, you should check the interface between the sockets and the motherboard, they are only held in place by the IO plate on the back and some solder. Constant fitment and removal will weaken the contacts and maybe even break them. If this is the only problem, you can resolder them.
5/13/2013 5:34:40 PM • Intel DG41RQ... • Answered on May 13, 2013
Random reboot cpu
try with a other PSU. proberly electrical problem.
5/12/2013 9:18:20 PM • Intel DG41RQ... • Answered on May 12, 2013
..................My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) .Problem is iwant to buy a new graphics card
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
3/10/2013 4:35:40 AM • Intel DG41RQ... • Answered on Mar 10, 2013
0answers
Monitor display
No SignalNo video signal(Monitors may also do this, and state Power Saver Mode, or Sleep Mode; instead of No Signal)1) Check the monitor cable. Has to be ruled out before going on.Either use it on another known to be working computer, and monitor; or use another known working monitor, and cable on your computer.Monitor cable checks out go on2) From here the logical assumption would be to check graphics.If the graphics are coming from the motherboard, Integrated Graphics; then use a graphics card.If the graphics is from a graphics card, use a known to be working one, for a test.[ The I/O area is on the back of the computer. I/O stands for Input/Output. It refers to the Input and Output devices that are connected to the computer; in the rear area.Mouse, Keyboard, Monitor, audio cables, etc.If the monitor is connected in the I/O area, the computer is using Integrated Graphics. In the past we used to refer it as OnBoard Graphics.ON the motherBOARD.If it is a graphics card being used, it will be in one of the horizontal expansion slots, on the back of the computer ]However I would like you to jump past that.Check instead;1) Is the computer dirty inside? If the Processor overheats it turns off.(BIOS turns it off) This is a fail safe feature built-in. Keeps the Processor from burning up. (Literally)Clean the inside of the computer out with a can, or two of compressed air for computers. Use Q-tips, and/or small soft brush (Makeup brush?), to dislodge the heavy 'Gunk', so the air can remove it easier. 2) Ram Memory:Remove all ram memory modules. ('Stick') Clean the gold plated contact pins with a pencil eraser.If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band of the pencil, touch the gold plated contact pins.http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpgHandle the ram memory module by the BODY.The Body is everywhere on the ram memory module, EXCEPT the gold plated contact pins.The Body is coated with a see-through protective plastic.Rub up, and down, and across; on EACH contact pin, BOTH sides.Use air to remove the eraser dust. You can use a can of compressed air for computers, if available; or air pressure from your mouth will be sufficient.Reinstall.3) Power Supply:There are two main issues for desktop computer failure;A) The computer is dirty insideB) Power Supply failureRam Memory contact pins cleaning is an add-on; but necessary.With a Power Supply having a weak voltage power rail, you could see LED's light, and fans spin; but NOT have enough power to turn the Processor on.1) If ALL of the LED's (Light Emitting Diode) were on at once, they would use less than 1 Watt of power.2) EACH fan uses 2 to 3 Watts of power.3) A typical Processor can use from 51 to 125 Watts of power. Just depends on what Processor it is.That is why you can see LED's light, and fans spin, but no signal.Use a KNOWN to be good, Compatible power supply; for a test unit.Or;Use a multimeter to test the 3 main voltages;3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage. (DCV)[In comparison two D cell flashlight batteries produce 3 Volts DC ]For additional questions please post in a Comment.Regards,joecoolvette
12/26/2012 10:00:09 AM • Intel DG41RQ... • Answered on Dec 26, 2012
How to connect power switch to mother board
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029925.htmClick on -Intel Desktop Board DG41RQ Product Guide - English (PDF)Bookmarks menu to the left -1) Click on the + sign to the left of -1 Desktop Board FeaturesClick right on - Desktop Board ComponentsOr go to Page 11. (Adobe Reader page number box at top)Front Panel header location marked by P, in the figure.2) Click on the + sign to the left of -Connecting to the Internal Headers and Connectors,in the Bookmarks menu.Click on - Front Panel headerMotherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.Two rows of contact pins.The Top row is numbered EVEN.Starting at the Left side going across to the Right, Top row;Pins 2, 4, 6, and 8. There is NO pin 10.The Bottom row is numbered ODD.Starting at the Left side going across to the Right, Bottom row;Pins 1, 3, 5, 7, and 9.A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)Pin 1 is for the Positive wire.If the HDD LED is dim when the harddrive is active, switch the wires around.B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.D) Pins 2 and 4 are for the Power On LED. (Light)This IS for a -> 2 wire LED. (Light)Pin 2 is for the Positive wire.If the PWR LED is dim when the computer is on, switch the wires around.E) Pins 6 and 8 are for the Power On switch.To the left of the Front Panel header is a 3-pin header.This is the Alternate Front Panel LED header.If you have a -> 3-wire LED, it connects here.Also wanted you to have the motherboard manual.Regards,joecoolvette
11/5/2012 3:49:29 AM • Intel DG41RQ... • Answered on Nov 05, 2012
I DONT HAVE INTERNET DRIVERS
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers the driver might be on the disc supplied by your ISP internet service provider or the motherboard disc or you might download one if you dont have on a diskif you dont have either of these disk a you will need to use a computer with an internet connection to download the appropriate driver download the driver to a portable usb drive then install it from the usb drivehttp://download.cnet.com/network-intel-r-pro/3000-2112_4-109070.htmlhttp://download.cnet.com/intel-r-82559-fast/3000-2112_4-56047.html
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
if you need more help with this post a replyhope this helps
9/2/2012 10:05:13 PM • Intel DG41RQ... • Answered on Sep 02, 2012
Display port of motherboard is not working properly?
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
7/14/2012 8:54:07 PM • Intel DG41RQ... • Answered on Jul 14, 2012
I have dg41rq intel mother board. RAM is 2gb 800 Mhz of dgnet. When booted shows memory decreased 476 mb see event log
Ram is Random access Memory Ram is temporary memory your computer uses to store things you are working on for quick access later on Ram is faster than your hard drive so things you are working on are temporarly stored there so you dont have to waite while it loads The more ram you have the more programs you can have running at the same time you could either uninstall some of the programs running at the same time or stop them running until you need them if you right click in the bottom toolbar select taskmanager you will see whats running in application and processes you will see what is ticking overthat way you will no what is running and needs to be stopped or uninstalled if you see something running that should not be select end now
For the virtual memory follow these instructions:Right click on My Computerselect properties.On this screen select AdvancedClick the Settings button in the Performance sectionClick the Advanced tab on the Performance Options screenClick the change button
On the Virtual Memory screen, check if it is set to System Managed size
If so select custom and increase the size from what it is currently
For example if it is set to 512MB set it to 1024MBIf it is set to custom try setting it to System managed size You will need to reboot after making the change
hope it helps
4/24/2012 9:23:43 AM • Intel DG41RQ... • Answered on Apr 24, 2012
Intel dg41rqi not working
The RAM module is either incompatible or faulty or not seated properly.
3/26/2012 2:30:35 AM • Intel DG41RQ... • Answered on Mar 26, 2012
Intel DG41RQ Motherboard &  Core 2 Duo E7500 Processor Bundle (INTEL DG41RQ MB & CORE 2 DUO ...) Logo
60 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
system config intel
  • Computers & Internet
