20 Most Recent
Asrock G41M-S M/board - Intel G41+ICH7, 1600(oc) MHz FSB, Dual DDR2 1066, PCIE, int VGA, SATAII Motherboard Questions & Answers
I wish to instal a
Just go to Control Panel-Divice Manager and disable it, after you intall the new one.
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards.
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo
and all 3 same reasons.
and all 3 same answers. zero
no I added one, coin cell is dead at 7 years, you are
2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
Mac adress are invalid in both CMOS and Flash
i have your problem.but when i use asrock mac tool it said "Not supported"!.infact it not supported mac address on stick on main board!but my hope was the mac 6 digit that newer tool write.then i change my mac by mac changer from windows and then set that mac to bois and flash by asrock mac tool.every thing get ok:)
