20 Most Recent Gateway LT2021u Netbook Questions & Answers
2answers
Keypad doesn't work
Keypad or the Touchpad? Are you saying your keys don't work or is it that the mouse pointer is frozen and not working?If it's the touchpad and mouse pointer:I think you have the Touch Pad disabled. You can toggle the touch pad between enable and disable by a couple of ways depending on the manufacturer. On some at the very top of the touchpad there might be a button in the middle that you can press that toggles the touchpad. On others it might be a sequence of key strokes. For example you might have to Press and Hold the ALT or FN key then hit the corresponding key at the top of the keyboard that toggles it. Most times the correct key to hit will have the icon of a finger pointing at a square area that represents the touchpad.If it's the Keyboard:Maybe your keyboard has been hijacked by a virus or infection. Maybe you spilled a liquid on the keyboard. Maybe the keyboard cable needs to be reseated ( taken out and put back in).Have you tried your keyboard in Safe Mode? Boot into Safe Mode and see if the Keyboard works, if so you know you have a virus or infection.Go to www.google.com and in the search box type:"download.cnet.com" (without the quotes). Click the link to goto the site and look on the left side when the site opens up and you will see agray area that says FIND SOFTWARE. In the white search box under FindSoftware type: "Virtual Keyboard" (without the quotes) and click themirror to search. When the search results come back look for FREE VIRTUALKEYBOARD. Download and Install it. It's totally FREE. Alsouncheck anything that pops up other than the license agreement during thedownload and installation. You only want the Free Keyboard and not theother junk. You can use it to solve your keyboard problem. Just open up whatever it is youwant to type on such as the web address in an browser, a word document, etc.,then open the Free Virtual Keyboard and it will sit on top of whatever you weredoing. You can move it around so that it is not in your way also.
3/14/2014 1:03:15 AM • Gateway LT2021u... • Answered on Mar 14, 2014
manual
2answers
When I had XP, my webcam on Skype worked fine. I
Did you download the drivers via model or serial number. Generally the webcams drivers that come with Gateway are in three. Be sure you unistall the one that doesn't work before installing the other, restarting your computer each time. Also check the dates of the drives compared to the time you purchase the machine, some driver may be old or updated. Lastly, which i am sure you've done, make sure you have chosen the correct Operating System if you are not downloading the file from the web cammed computer.
5/19/2013 3:34:04 PM • Gateway LT2021u... • Answered on May 19, 2013
White screen problem on my netbook gateway lt2016u
I Got lt2016u/LT20 Gateway Netbook I need help restore my net-book and i need please restore it cause it got blue screen and keep going to slow and poping up errors messages PLEASE PLEASE help
4/3/2013 7:09:20 PM • Gateway LT2021u... • Answered on Apr 03, 2013
GATEWAY WINDOWS 7 FACTORY
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend. Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
2/15/2013 5:47:39 AM • Gateway LT2021u... • Answered on Feb 15, 2013
My gateway N214 SCREEN GOES WHITE
just remove the RAM then puts it back or removing the battery then power it on , check it
2/4/2013 5:56:57 PM • Gateway LT2021u... • Answered on Feb 04, 2013
Netbook keep stopping in the windows xp screen while starting up
The software needs to be reinstalled.
1/27/2013 7:47:42 PM • Gateway LT2021u... • Answered on Jan 27, 2013
Need to start windows setup no cd net book l20
Try these sites:http://support.gateway.com/s/software/microsof/7509595/install/install06.shtmlhttp://www.tomshardware.com/forum/53883-35-trouble-installing-windows-gateway-netbook
1/20/2013 7:30:58 PM • Gateway LT2021u... • Answered on Jan 20, 2013
Black screen gateway kav60? acer user i need something that wont use cd cause i dont have one!! something wit alt or w.e method with out cd thank u so much
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
12/25/2012 10:21:16 AM • Gateway LT2021u... • Answered on Dec 25, 2012
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
10/29/2012 9:18:39 PM • Gateway LT2021u... • Answered on Oct 29, 2012
Not receiving to my hotmai inbox that I have mail waiting on Christian Mingle and today I received notification tha I had mail waiting on Christian Mingle but had no mail
- Did you receiving mails from other Emails IDs? If Yes, then check your spam folder. Or may be these mails are SPAM.
7/27/2012 5:50:13 PM • Gateway LT2021u... • Answered on Jul 27, 2012
No bootable device
Could be one of three things.1. Check your BIOS before bootup and make sure your drive boot order is correct. You'll want to make sure the hard drive is first. This is also a great place to check to see if a hard drive shows up in the BIOS.2. Reseat the Hard Drive. Open the bottom panel of the netbook and find the hard drive. Remove the drive, place the drive back in, close the system up, and try booting again.3. Replace the hard drive.
7/19/2012 1:13:37 AM • Gateway LT2021u... • Answered on Jul 19, 2012
Reset administrator password without loggin in
I met the same troble with you, but i use Smartkey Windows Password Recovery to help me reset windows amin password, just do as the following steps,1. Install this Smartkey Windows Password Recovery on the computer that you're just using.2. Take the CD/DVD or USB drive and insert it on an open port on your computer.3. Run the utility and select the option to burn the utility to the CD/DVD or USB drive. See more detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
6/20/2012 3:16:00 AM • Gateway LT2021u... • Answered on Jun 20, 2012
Dead screen on acer aspire 4310 laptop
If everything else is lighting up and is working, hook a spare monitor to the video output usually on the back, if picture okay! the inverter board just below the screen is more likely the problem, or it is the built in backlight behind the display, "less likely" but, if both show the same symptom it is the video graphics card that is part of the motherboard.
4/20/2012 9:09:29 PM • Gateway LT2021u... • Answered on Apr 20, 2012
Error code on my gateway netbook
What were you doing when this happened?
3/29/2012 3:34:46 PM • Gateway LT2021u... • Answered on Mar 29, 2012
Gateway LT2021u Netbook Logo
99 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
keypad doesn 39 t work
  • Computers & Internet
