20 Most Recent Sony VAIO VGN-NW150J/S Notebook Questions & Answers
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
2/4/2018 10:48:03 PM • Sony VAIO... • Answered on Feb 04, 2018
The icons on are large and I did not change the settings
In control panel - display .... Change your resolution. Also - Do full housework on your registry and scan for viruses malware ect
1/29/2014 8:33:00 PM • Sony VAIO... • Answered on Jan 29, 2014
DARK SCREEN SONY VAIO VGN-NW150J
replace the inverter board it connects to the screen and, is usually at the top of the laptop under a panel between the screen hinges
2/4/2013 6:24:26 PM • Sony VAIO... • Answered on Feb 04, 2013
2answers
How do i replace my
you will have to open the laptop up by removing the screws and possibly the display aswell.
if you have no experience in fixing laptops i suggest leaving this to the local repair shop to be fixed. it requires time and patience.
in the mean time i will try and find a pdf document with step to step instructions
8/24/2012 10:03:06 PM • Sony VAIO... • Answered on Aug 24, 2012
0answers
I have a vaio nw150j with bad hard drive. What are the steps for ssd and new os install?
If you bought the same drive I don't see why you'd have to do anything to the Bios.
4/6/2012 1:07:48 AM • Sony VAIO... • Answered on Apr 06, 2012
I have a sony vaio VGN-NW150J, it had a virus and
You'll need to go to Sony's website and download new drivers for it.
Try this link.
8/29/2011 3:03:36 AM • Sony VAIO... • Answered on Aug 29, 2011
Screen is black when it's
Based on the information you have provided, it confirms the issue is related to the internal led lights of the notebook display.
However, I suggets that you connect any other external monitor to the computer to ensure the issue.
If the display is as expected in the external monitor, contact the Sony technical support team to get the internal hardware replaced for you.
Be careful if you are opening the computer, this voids the warranty.
It's always recommended to contact the sony service or any certified technician to handle such cases.
It may cause a more severe damage to your computer and result in shelling out more bucks to get it resolved.
7/12/2011 8:31:28 AM • Sony VAIO... • Answered on Jul 12, 2011
2answers
Hi, I have Sony Vaio,
HI,
go to following link and click on Download now and get your webcam drivers.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNW150J&upd_id=5051&os_id=49
Please don't forgot to rate if you get the solution.
6/3/2011 4:27:16 AM • Sony VAIO... • Answered on Jun 03, 2011
How do i replace my
you can call the SONY Technical support and give them the serial number of the laptop and they will immediately replace the keyboard.
5/30/2011 5:20:56 AM • Sony VAIO... • Answered on May 30, 2011
Hi! I installed windows 7
Hey,
Make sure you are downloading the correct driver for your webcam, and make sure that if you are installing 64bit windows 7 that you have a 64bit driver, and same with 32bit (im sure you are, but double check just in case).
If you are 100% sure of that, have a look through the drivers page for your laptop and look for a "chipset" update of some sort.
Hope this helps :)
5/25/2011 1:59:05 AM • Sony VAIO... • Answered on May 25, 2011
I cannot recover the bios
You mean you Forgot the Password?
Remove the cmos battery and hook it back in.
Hope this helps.
Cheers!!!
1/6/2011 6:07:05 AM • Sony VAIO... • Answered on Jan 06, 2011
Bios unlock
TO UNLOCk your BIOS you have to Disable it..
i ll advice you ro se a laptop technician..
12/21/2010 2:51:46 PM • Sony VAIO... • Answered on Dec 21, 2010
3answers
Typing in a electronic medical record online. the
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
12/22/2022 9:08:06 AM • Sony VAIO... • Answered on Dec 22, 2022
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop. Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185) This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information. Causes of Error Code 0xc0000185:- 1. Suffer a cable attachment joining to your system and the hard drive. 2. Defective or missing boot files. 3. The disk drive gets damaged. 4. Wrong disk drive. Solutions of Error Code 0xc0000185:- 1: Do sure that Wire is Correctly Connected [Only for PC] 2: Automated Repair 3: Check Hard Disk for Errors 4: Repair your System to Fix Error 0xc0000185 Full Solution - Error Code 0xc0000185 wgnanor-undefined-undefined-0_3.jpg
9/14/2022 11:53:07 AM • Sony VAIO... • Answered on Sep 14, 2022
Nao consigo instalar o drive de controle de massa no meu Sony Vaio PCG-792L. Como devo fazer
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
1/23/2019 7:29:29 PM • Sony VAIO... • Answered on Jan 23, 2019
How can dennythedon3003 help - if only he spoke English
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:39:57 PM • Sony VAIO... • Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu? thanks
11/30/2018 6:38:47 PM • Sony VAIO... • Answered on Nov 30, 2018
Denythedon3003 fixya spam loser - guess what country he's from - maybe Tom can block him
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
11/30/2018 6:25:34 PM • Sony VAIO... • Answered on Nov 30, 2018
Sony VAIO VGN-NW150J/S Notebook Logo
19 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
dark screen sony vaio vgn nw150j
  • Computers & Internet
