20 Most Recent HP ProBook 4510s FM849UT Notebook Questions & Answers
How to reset bios password on hp 6540b
I wish I could have tested it first but you can still try the Shotgun method. Your options are. Contact HP. http://welcome.hp.com/country/w1/en/contact_us.html Or download these files. https://www.dropbox.com/sh/zu4kdgxm052l87d/AAAMi-kfX4AVH8oTCbsOM4X9a?dl=0 Insert clean USB flash drive. Then run USB Image tool. Choose the flash drive then click on RESTORE. After restore remove flash drive. Insert flash drive into locked laptop and boot. "If HDD is installed remove before booting." At C:\OUTPUT type CD.. "Then hit enter" Type HPBR "Then hit enter" First thing is to save your settings. Select #3 re-program. Press "S" to save system information. Type HPBR and hit enter. Since your model is not listed select "SHOTGUN." After reboot repeat "SHOTGUN" a second time. Let me know the result so I can update my list. Some instructions here. "If you cannot boot from USB there are instructions to make a bootable HDD." http://mazzifsoftware.blogspot.com/2014/01/hp-bios-unlock-for-dos.html More help here. http://forums.mydigitallife.info/threads/49497-HP-Probook-Elitebook-BIOS-Password-Reset-Utility?s=ad18a86dbbaf34999e22b1225a42a395 REO I must inform you that these services are not endorsed by HP, and that HP is not responsible for any damage that may arise to your system by using these services. Please be aware that you do this at your own risk.
3/8/2018 3:17:08 PM • HP ProBook 4510s... • Answered on Mar 08, 2018
A major problem of Skype!
what OS? windows, and What windows, XP? HP sold it with 7 different OS, (xp to w7 ./32/64bit) and linux. I cant know what you use for sound at all. the PC has sound chip and 2 speakers and mic., external speakers, or sound buds, what? tell what you have first. 4510s tells little. if you have USB headphones there, it WILL mess up. USB adds a 2nd sound chip set and they clash with onboard set. in fact buying new headphones with USB sound and boom mic built in then going in to device manager and disabling the onboard sound makes the head phones work real well. its not metal bs. sorry. that is jive. i the sound test fails, then it failing that you can be sure. if no bud, or headphones of any kind and only internal speaker ;.mic is used then down load the drivers from HP for you sound is that hard? here https://support.hp.com/us-en/product/HP-ProBook-4510s-Notebook-PC/3934828
9/2/2017 2:57:48 PM • HP ProBook 4510s... • Answered on Sep 02, 2017
0answers
System not booting normally
Its going to safe mode every time...actually Safe Mode is for to change any setting or get backup and some more... better to change the OS.. everything will be perfect after taking data backup... i think it will help u....
4/6/2014 5:46:06 PM • HP ProBook 4510s... • Answered on Apr 06, 2014
My toshiba laptop screen is completely black
Your laptop screen may be dead. Please test it using an external monitor. If it works good with an external monitor, then you need to replace the screen. eBay.com is a good source.
3/2/2014 4:00:35 AM • HP ProBook 4510s... • Answered on Mar 02, 2014
0answers
Water fall into my laptop, whenever i switched it on nothing appear on the screen
you should not turn it on, open it ,make sure, its completely dry on every part of motherboard, you can use a little bit of dryer heating, fix everything, try turning on, If not take to store for repairing., water makes the circuit to go shortcircuit, should never turn on system on water spill issues.
12/15/2013 8:13:27 PM • HP ProBook 4510s... • Answered on Dec 15, 2013
Water fall into my laptop, whenever i switched it on nothing appear on the screen and also it shut down automatically after 20 secs
did u try to dry the wet portion if not blow hot air trough the slots of body to dry the moisture about 10 min then try to power on
12/15/2013 7:34:49 PM • HP ProBook 4510s... • Answered on Dec 15, 2013
2answers
Hi, i hav a probook 4510s laptop & i cant get the mouse pad to work... when the lappy is starting up, in the left hand top corner is says - no mouse detected. please help!
If this is a recent occurance, shut down, unplug, remove battery, plug in, push the on/off button and do a System Restore to a date before this problem. Perhaps the TouchPad driver is in error. You can try a external USB mouse to troubleshoot the problem in Device Manager to verify the driver or device isn't in error. I think HP TouchPad software is Synaptics Pointing Device, check your your Tray Notification Area for the icon, right click, select Pointing Device Properties. Or Control Panel, select Mouse.
11/29/2013 1:09:51 AM • HP ProBook 4510s... • Answered on Nov 29, 2013
Reset battery
No there is not, please dispose of it properly and replace it
10/6/2013 2:10:42 PM • HP ProBook 4510s... • Answered on Oct 06, 2013
Missing Operating System on D: partition Bootup
Follow the steps from this site http://www.wikihow.com/Change-the-Active-Partition-of-Your-Hard-Disk-with-Parted-Magic. When you changed the active partition you told the computer to look for information from the wrong partition. Using the program from that site will allow you to make the other partition active again. You'll then be able to boot into Windows again. As far as making backup discs, I believe you hit F11 while booting to access the recovery partition. From there you can make your recovery discs. Not 100 percent sure on that though. And you will need to get the windows partition set back as active first.
6/20/2013 2:51:21 AM • HP ProBook 4510s... • Answered on Jun 20, 2013
How to do a Destructive Recovery OR create Recovery Disks under Windows XP
you must HOLD the CTRL KEY + F11 OR F12, AND go to the reconvery factory setup.God bless you
6/16/2013 11:04:28 AM • HP ProBook 4510s... • Answered on Jun 16, 2013
0answers
2answers
Hi When i switch on my
try to reset BIOS
5/8/2013 3:10:57 PM • HP ProBook 4510s... • Answered on May 08, 2013
Kkk
What is the problem question Brandon Sadler?Post back in a CommentRegards,joecoolvette
5/4/2013 3:55:43 AM • HP ProBook 4510s... • Answered on May 04, 2013
Hp probook 4510s key board problem
You can try cleaning keyboard with a toothbrush, but with repairing computers for 15 years I find - a) buy a USB keyboardb) buy and install a new laptop keyboard (easy-ish install)c) install Sharpkeys - a program that changes a key of your choice to act like something else (example # becomes K)
4/19/2013 6:32:04 PM • HP ProBook 4510s... • Answered on Apr 19, 2013
HP ProBook 4510s FM849UT Notebook Logo
144 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProBook HP
  • ProBook HP
Most Popular Question
missing operating system d partition
  • Computers & Internet
