20 Most Recent
Acer Aspire 1410-8414 Netbook Questions & Answers
Acer 1410 can't turn on with cord plugged in
The battery isn't charging, from what you describe. Sounds like a bent pin, or a bad charging circuit. Waranty should cover, unless it was dropped or 'abused,' assuming that it was a new present. Take a quick look at the battery connection.
Forgot my windows 7, password.
If you have a bootable CD/USB drive,some password tools can be burn to it and you can boot your computer from USB to run the software,so that you can recover/remove Windows 7 password from USB.Such as Daos Windows 7 Password Recovery Tool,here I just list the simple steps:Step 1: Download Daos Windows 7 Password Recovery Tool/Windows Password RescuerStep 2: Run it to burn to bootable CD/DVD or USB flash driveStep 3: BIOS setting of your locked computer to boot form CD or USBStep 4: Reset Windows 7 password on a friendly window after "Daos Windows 7 Password Recovery Tool" starts.You also can use Daos Windows 7 Password Recovery Tool to add a new user with administrator privilege to your Windows. With this New user account you can logon your locked computer directly.
http://www.daossoft.com/windows-7-password-recovery/how-to-use-windows-7-password-recovery-tool.html
Use to connect to internet now it won't find it
open control panel through start buttonlook for wireless iconclick on that and see if it's activestart buttoncontrol panelsystemdevice managerthen look for network adapters see if they are happy(no yellow ? marks)restart machine try again
How to change hard drive on acer aspire 1410
Hello
Here is some steps you can follow to change/replace you HDD.
Step 1: remove power cord, and battery
Step 2: flip computer upside down
Step 3: find the hard drive bay, there might be a cylinder like icon near it, and it will be close to the front of the system.
Step 4: remove the screws, likely 2 screws.
Step 5: on removing the plastic lid you will see a metallic box, with a plastic strip on top of it.
Step 6: on the side that has extra space there will be 1 or 2 screws, undo these
Step 7: pull the plastic strip toward the side of the computer that has space open and the whole caddy should pop out.
Step 8: take the 4 screws out of the side of the caddy and the hard drive will just slid out.
Step 9: just put new one in the same way the old one was. and reverse
the steps and put your recovery disk in to install your OS.
Hope this can steer you in the right direction.
Do not hesitate to let me know if you do not understand.
Kind regards
Andrea
I have a virus on
TRY SAFE MODE AND DOWNLOAD ANTIVIRUS .EVEN IF THAT DOESNT WORK U HAVE TO FORMAT SORRY.
DO TELL ME WHETHER SAFE MODE WORKED????
My computer when i start
when task manager appears on the black screen, click on applications tab and then click new task and type explorer.exe and then press ok. your normal desktop should appear
How do i turn on
look at the switch at the bottom of your laptop's wi-fi connection light =)
Two nights ago I left my Acer Aspire 1410 running
you have over heated your machine as there was no ventilation possible damage to your cpu and bios chips these are all onboard mounted on the motherboard and as such the mother board will possibly have to be replaced would suggest you have professionally checked out
The backlight keeps shutting down any fixes?
All I can suggest is to replace the ballast unit. That is the high voltage generator that supplies the back light. It is not very likely to be the flourecent lamps that are embedded within the screen. If they become faulty, one may fail leaving a dull patch on the screen.
There is however a possibillity that you have a poor contact on the connector either end of the display cable.
Hope that helps.
Screen is only 75% of
It's probably the device-drivers for your video-card
(the wrong driver won't "maximize" the screen)
or it could be just the "settings" for the current device-driver
(wrong "resolution" causes the wallpaper to not be maximized).
User manual
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS1410_1680_Eng_0625.pdf
you can find the manual on the link above
