20 Most Recent
MSI Wind U123-002US Netbook Questions & Answers
Cannot open wabcam
download the youcam in to the google.and install to your netbook. i hope you driver in camera is already installed
i hope am i help you thnx
11/26/2013 7:49:03 AM •
MSI Wind...
Answered
on Nov 26, 2013
I HAVE MSI NETBOOK WITH
USING THE Installer of your XP installer to portable dvd drive it still not working to reinstall the windows. the problem of your msi netbook is the hard drive. may sulotion for that. used desktop CPU and put the harddrive of your msi and into the CPU of desktop. then Checkdisk your hard drive.
and after that finish the checkdisk. get your hard drive and put again to your netbook. and try to reinstall then XP.
thnx i hope am i share my knowlage
11/26/2013 7:45:33 AM •
MSI Wind...
Answered
on Nov 26, 2013
PXE-E61 Media test failure, check cable
YOUR NEW HARDDRIVE SATA THEY HAVE A BAD SECTOR. UNEED TO CHECK DISK TO OTHER COMPUTER OR HDD REPAIR FOR FIXING THE BADSECTOR THE ACCESS UR HARDDRIVE. TTHEN PUT BACK TO YOUR COMPUTER AND THEN TRY TO PORMAT AGAIN IN XP OR OTHER WINDOWS OS.. TRY TNX
11/19/2013 11:18:40 AM •
MSI Wind...
Answered
on Nov 19, 2013
Reboot following install of new hard drive
You need to get an external dvd drive, then either the recovery disk that came with your computer (you may have had to make it), or you need a copy of Windows that is the same version as the one installed on your computer from the factory (look at the Certificate of Authenticity on the bottom of laptop or under the battery). Turn on the computer, then tap the F11 key until you get the "boot menu". Insert your disk into the DVD drive, and select USB DVD drive from the boot menu... follow the installation instructions from there.
11/18/2013 11:05:03 PM •
MSI Wind...
Answered
on Nov 18, 2013
How to enter recovery mode
This is the easiest way that can be completed. Download Quick Boot tool from Google Play Store. Click Here to download, and Install this tool in your device. Now, Run this tools.
1/12/2015 2:45:09 AM •
MSI Wind...
Answered
on Jan 12, 2015
Extend screen to tv while keeping desktop on computer
Depending on the brand, you should hit function, then F7.
Then you can cycle through the modes. Normal (just the laptop screen) , TV (or video) out, and last mode is screen AND TV out.
I used to set up laptops for presentations, and I would hook up a video projector to the VGA out, then the presenter could look at his screen and use the mouse while folks followed him on the big screen behind him.
5/12/2014 4:30:29 PM •
MSI Wind...
Answered
on May 12, 2014
Msi mini laptop
your master boot record MBR is damaged and your harddisk looks missing or blank to boot up. run cd and go to command prompt.In black window were :>chkdsk c: /f then press enter. type as shown from prompt with space between k c and : /...
9/4/2013 6:20:14 PM •
MSI Wind...
Answered
on Sep 04, 2013
My msi windnotebook is always 0% charge
If the
laptop battery is more than 3 - 4 years old then the battery could be worn out.
Rechargeable batteries have a finite number of charge and discharge cycles and
will lose their charge capacity over time, i.e. won't charge to 100% and
gradually the charge reduces until the battery won't charge up at all. OR The
battery shows a 100% charge but when the adapter is disconnected the battery
drops off to zero capacity in a very short time. If the battery drops to an
unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged
state for long periods.
4/26/2013 11:51:08 AM •
MSI Wind...
Answered
on Apr 26, 2013
