20 Most Recent
HP C4680 All-In-One Inkjet Printer Questions & Answers
I just want to print
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .Use the test print to calbrate the SCANNER.
Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
8/29/2022 10:17:08 AM •
HP C4680...
Answered
on Aug 29, 2022
Error Message when printing
Hi there
This error I not think you will find on the hole internet I not seen this number error befor, this is a new error....
8/12/2014 4:57:59 AM •
HP C4680...
Answered
on Aug 12, 2014
Fix carriage jam
Unplug the printer.
Move the carriage to the center of the printer.
Wait at least 3 minutes.
Plug printer back in.
12/31/2013 2:51:10 AM •
HP C4680...
Answered
on Dec 31, 2013
Print cartridge problem hp c4680
1. remove all the ink cartridges from the printer and then clean the copper contacts with a lint free cloth put it back in and check if that helps..2. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec. then release the button and then plug in the power chord at the back of the printer and check if that helps..3. try changing the ink cartridges as it might be an issue with the ink cartridges... however if you have already done that then most probably its an issue with the printer hardware.. you should call HP and ask for replacement...
10/21/2013 7:56:43 PM •
HP C4680...
Answered
on Oct 21, 2013
C4680 print cartridge problem
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
4/13/2013 3:37:11 AM •
HP C4680...
Answered
on Apr 13, 2013
Its no networking with my computer
Turn off the printer and the computer.
Please check the usb connections making they are well connected.
Turn on your printer and the PC.
9/29/2011 8:54:44 PM •
HP C4680...
Answered
on Sep 29, 2011
I need to print a
Do you want to print in Mirror Image ?
Follow the steps and you will be able to do so,
Click on Start button
Open Control Panel
Open Printers
Highlight the Printer icon name ( HP Photosmart C4680 All-in-One Series )
Right click on the Printer icon and Left click on Printing Properties
Under Advanced Tab click Mirror Image ON
Click Apply - Click OK
Try to print and it will print in Mirror Image.
Thank you for contacting Fixya
*Please rate this solution with thumbs up
9/14/2011 6:35:54 PM •
HP C4680...
Answered
on Sep 14, 2011
