20 Most Recent
Honeywell Safes 2072 Digital Anti-Theft Safe - 1.06 cu. ft Questions & Answers
How to order keys
There should be a number on there that you can call to order the keys. However if there is not a number then the question is is the safe locked? If it is there may be no way to get into the safe without drilling it. We hope this helps.
I own a Honeywell safe digital 1.06 cu #2072 when
If you are using the key, you don't need to enter a code. To open with the key only, please do the following:
1. Remove the key lock cover located beneath the digital keypad.
2. Insert one of the Emergency Override keys (2 included) into the bypass lock and turn to the left.
3. Pull the handle up and pull open the safe door.
I apologise if I have misunderstood the question. If you are unable to open the safe using either the key OR the code rather than the key AND the code, please post back and I will try to assist you further.
Regards,
BElectric
My Honeywell Safe model 5005W keeps beeping, even though I put new batteries in it. What do I need to do, to shut it up?
The batteries must be installed before using your safe. The battery compartment is located inside the safe on the lock cover panel.
Note: If both green and red LED's are on, it is an indicator that the batteries are weak and must be changed immediately. The User Code will not be erased if power is restored by replacing the
batteries within 30 minutes. After 30 minutes, the User Code will be erased and will need to be reprogrammed. Weak or dead batteries should be replaced immediately and all 4 batteries should be changed. To replace the batteries please follow STEPS 1 - 3. Remember to always remove batteries from safe if not using for an extended period of time. If your batteries are completely dead and you cannot o pen the safe by using the digital keypad, use the override access key to open safe
and access the battery compartment. The use of Non-alkaline or rechargeable batteries is NOT
RECOMMENDED.
