20 Most Recent
Samsung SP50L6HX 50" DLP HDTV Questions & Answers
Making beep sound lamp
Hello, I think I understand the question, your TV is making a beeping sound indicating its time to change the lamp? If so I suggest you go with the original Philips on the link below, to get the brightest image possible.
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
How doi get lamp out
If you take the panel off the back of the telly its right in front of you you take one screw out and slide out the little box with the lamp in it
I need a lamp for it
Just Google the model number with "lamp" and you can take your pick of replacement lamps.
Niosey bad picture
If model number indicated here is correct does it do it on all inputs(tuner ,DVD inputs etc)?
No picture and a fast clicking sound
The first thing to check would be the status if the lamp especially if you have not replaced it in a while. Old/burntout lamps consure a lot more power than they should there by exerting overload on the lamp driver(ballast) and hence the power supply. So please check the status of the lamp and let me know.
My tv is only clicking, no picture or sound, why?
The tv projection lamp inside the tv now it is 1 1/2 or 2 years already,tv in used 4 or 5 hrs everyday?Yes,than the tv projection lamp life have ended,require replacement too.The clickings sounds,it is the board that call the Ballast board it is dead too,the clicking sound mean the Ballast board continueing tried to ignite the tv projection lamp.
The picture has suddenly gone dark. We can still
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
