20 Most Recent Mitsubishi WD-82837 82 in. HDTV DLP TV Questions & Answers
Mitsubishi tv WD 82837.turns on for about 30seconds, then shuts down with a red blinking light
Can you try this and post the result(s) here? - When the TV is OFF, Press & Hold the "Power" button for a bit more than 30 seconds. Please post the result here...Thnx
12/31/2019 4:09:57 PM • Mitsubishi... • Answered on Dec 31, 2019
2answers
Green status light FAST blinking and does not
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT [email protected]
10/17/2016 1:01:18 AM • Mitsubishi... • Answered on Oct 17, 2016
Mitsubishi WD-82837 pop noise and no power
Sounds like your bulb blew. Here is a link to a very good priced replacement bulb with housing . These are very simple to change yourself. http://www.projectorlampsworld.com/projector-manual/mitsubishi-wd-82837.html also, here is a link to a video showing how easy it is. They are made to be replaced by the consumer. How to replace the lamp in your Mitsubishi TV: http://youtu.be/_ONPuB5L-x4 Note, your bulb assembly may vary slightly from the one in the video, but it should come out and go in the same way. You will need a plastic grocery bag or small garbage bag, some rubber, or latex, or clean cloth gloves, and a medium phillips screwdriver. Good luck!
5/16/2014 11:56:25 AM • Mitsubishi... • Answered on May 16, 2014
TV Lost HDMI-1...Does not respond and is greyed out...
Input board (rear board) sensing bad.
5/9/2014 4:13:28 AM • Mitsubishi... • Answered on May 09, 2014
How to replace power supply board on wd-82837
How do you know it needs one ? That sounds more like a lamp, color wheel or DM module issue (if set uses one.)
5/8/2014 3:54:42 AM • Mitsubishi... • Answered on May 08, 2014
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
2/12/2014 10:49:42 PM • Mitsubishi... • Answered on Feb 12, 2014
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
2/12/2014 10:46:37 PM • Mitsubishi... • Answered on Feb 12, 2014
What is causing the lamp to keep going out on an 82" 837 Mitsubishi TV?
If a OEM Mitsubishi lamp was used you likely have a problem with the Ballast that drives or powers the lamp---the two pin socket for the lamp goes directly to the Ballast.
6/1/2012 5:51:27 PM • Mitsubishi... • Answered on Jun 01, 2012
I have a mitsubishi
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
12/9/2010 4:43:02 PM • Mitsubishi... • Answered on Dec 09, 2010
2answers
My tv blinks 6x red and 1x yellow. whats that mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
1/9/2023 7:23:43 AM • Mitsubishi WD... • Answered on Jan 09, 2023
0answers
How to replace the main board on a mitsubishi WD-60C8
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
1/18/2018 11:51:33 PM • Mitsubishi WD... • Answered on Jan 18, 2018
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
1/2/2018 10:55:36 AM • Mitsubishi WD... • Answered on Jan 02, 2018
Mitsubishi WD-82837 82 in. HDTV DLP TV Logo
29 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi tv wd 82837 turns about
  • Televison & Video
