20 Most Recent
Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME WALL AC CHARGER Questions & Answers
Iphone problem
Hi, sorry to hear you're having this issue. I would recommend saving all of your settings (photos include) on your computer and restoring your phone to factory settings.
IPhone charging not supported with this accessory
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Iphone 3gs unlock
One of the best method to unlock an iPhone 3GS is to unlock using remote unlocking service. You can get the remote unlocking service for an iPhone 3GS from
www.wickedunlock.com/apple-iphone-3gs/rs16wp9/ at affordable cost. This method of unlocking is very simple. Here are the steps for unlocking an iPhone 3GS,
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.2. Install the latest version of iTunes.3. Make sure your Apple iPhone 3GS phone software is updated to the latest version using the iTunes software.4. Connect your Apple iPhone 3GS to iTunes with a NOT ACCEPTED SIM card.5. Wait until iTunes detects your Apple iPhone 3GS.6. Disconnect your Apple iPhone 3GS and reconnect it after 10 seconds.7. Your Apple iPhone 3GS is now unlocked.This method of unlocking doesn't require a jailbreak too. Anyway if you need to jailbreak your iPhone 3GS, You can get the guide from www.absinthejailbreak.com All the best mate.
How to insert sim card
use a paper clip or a thumb tac to put in the hole on the top of the iphone 3g models then press down then pull up to remove the tray .... make shure you put it back afterwards
I need a PUK code for my iphone 3gs
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Mms failure on iphone 3g. when trying to send
Did you just try to restart your iphone by turning it off like this:hold on the home button and the power button,until "slide to power off" appear and then slide to power off.then turn it on, and try again to send your pic.is it working ?
My iphone only sync's photo's
You must select the sync music or any other media you wish checkbox in iTunes on the iPhone page when it is plugged in. Then click sync once you have checked the sync music checkbox.
