20 Most Recent
Nokia 7610 Supernova Cell Phone Questions & Answers
HOW TO UNLOCK MEMORY CARD OF NOKIA 7610 WHEN YOU
HI DEAR
JUST INSTALL A SOFTWARE CALLED FEXPLORE IN UR PHONE(DOWNLOAD FRM HERE WWW.USEFULLSOFTZ.XTGEM.COM).THEN OPEN FEXPLORER GO TO E DRIVE THEN IN SYS FOLDER THERE U WILL SEE A FILE CALLED MMCSTOE OPEN IT WITH UR NOTEPAD.U WILL GET UR PASSWORD THERE
FOR MORE TIPS AND TRICKS EMAIL ME
[email protected]
Reset code
I've ever had this problem too so I called the Nokia centre and they told me to go to the Menu-Setting-Restore Factory Setting. Done it's fixed by itself. Anyway sometimes you couldn't activated the camera when the battery is running low.
I have forgot the security code of nokia 7610
hi
visit on this site http://www.unlockme.co.uk/master.php
after visiting on that site you have to enter your phone's imei no. in the textbox which are given on that page
after entering your imei no. click on get master code button to get your phone's master code
Camera standby
Corrupted software
It
isn't often that Apple gives specific directions about how to fix your
problem! Restoring the iPhone 4 will erase everything on it, so make
sure everything on the iPhone 4 is stored elsewhere prior to restoring.
To restore, connect your iPhone 4 to a computer with iTunes installed.
Click "Restore" on the iPhone 4 summary page (click on your iPhone icon
on the left menu to find this page). Follow the directions to restore.
If your iPhone 4 displays the text "Please wait. Very Low Battery,"
leave it plugged in. This charges the iPhone 4 enough to be able to
restore. If the iPhone 4 hangs on this screen for long periods of time,
you may need a new battery. Force restore mode
If
your iPhone 4 is hanging with an Apple logo, or exhibiting some other
software problem that prevents iTunes from recognizing it, you can force
it into recovery/restore mode and then use iTunes to restore the software. If
the device is powered off, plug one end of your USB cable into the
iPhone 4 and leave the other end disconnected. Press down on the Home
button, and keep holding it down while you plug the USB cable into your
computer. After 5-10 seconds, you should see a "Please Connect to
iTunes" image on the iPhone 4, and iTunes should prompt you to restore
the software; follow the prompts and the instructions given above. If
the device is powered on, hold down both the power and home buttons
until the device reboots and displays the "Connect to iTunes" image
(generally, 5-15 seconds).God bless you
Forgot security code reset
Hi, If you have forgotten the security code of your Nokia 2610, You
can do a master reset to it. This could restore your phone with default
factory settings. So the security code also changes to default 12345. You can get the master reset code for a Nokia 7610 from
www.unlocking4free.com for free. Good luck mate.
Network does not
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
I can turn it on, and if i dial a numbre
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
7610 supernova locked code
Hi what kind of lock code are you asking for? Is it a phone lock or a network lock? If it is a phone lock, You must do a master reset for your Nokia 7610. This could restore your phone with default factory settings.If it is a network lock, You need to enter the unlock code. You can get the unlock code either from your network provider or from any trusted vendor online. For example you can get the unlock code from
www.unlocking4u.com/nokia-7610-supernova/rs6wp9/ at affordable cost.Here are the steps for unlocking a Nokia 7610 SUPERNOVA,1 - Switch on your Nokia 7610 SUPERNOVA
without any sim card.
2 - Don't bother as to what is displayed on your Nokia 7610 SUPERNOVA.
3 - Compose
#pw+CODE+1#.
4 - The Nokia 7610 SUPERNOVA would then display the message "SIM Restriction Off" and will be unlocked!
I FORGET MY SUPERNOVA 7610
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site
www.unlock-free.com/nokia-master , it has the best services for the master reset code for your Nokia 7610 model mobile.....I hope that it may helpful to you....
