20 Most Recent
Matsonic MS9158EP (DSMTSMS9158EP) Motherboard Questions & Answers
Why my pc (ms915ep-mastonic) not
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
7/31/2011 8:38:27 PM •
Matsonic...
Answered
on Jul 31, 2011
I need all drivers
Its hard to find your drivers in google.
1st download and try to install these.
http://www.mediafire.com/?9qcuwdwcbcml2vithe link above is a lan driver.try if it will work with your motherboard.
then try to access the internet. Once you have access to the internet, download this software
http://www.mediafire.com/?hwh6v0yymmrsho8After downloading this software, extract and install it.
If your asked for the serial key, you will find it in the extracted folder. The name is Key.bmp
after entering the Key, Start Scan then after scanning. download the drivers of your motherboard.
Goodluck.
Please give me update if my solution worked. thanks.
6/28/2011 6:20:10 AM •
Matsonic...
Answered
on Jun 28, 2011
Sound card is not active
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
12/7/2010 4:40:37 PM •
Matsonic...
Answered
on Dec 07, 2010
Info to connect front panel leds
Each of the ends of the cables that lead to the LEDs should be labelled, e.g., 'PWR/power', 'RST/reset', 'SPK/speaker', 'HDLED/hard-drive-LED', 'PWRLED/power-LED'.
Connect each labelled connector to the labelled pins on the motherboard.
5/29/2010 2:06:18 PM •
Matsonic...
Answered
on May 29, 2010
I forgot the way to connect the cables to the
we give power to fan from mother there there3/4 pin squiri white potr.we give power to bordfrom smps 9/12 white squite connecter.we join power/ led/ reset /usb cable between casing and mother bord. we can see this thing written in motherbord and wire connecter(small)
10/31/2009 11:42:00 AM •
Matsonic...
Answered
on Oct 31, 2009
Drivers
I have a trouble with my PC. Please send me the software motherboard by my mail to update the system device. Thank You
10/25/2009 4:41:35 PM •
Matsonic...
Answered
on Oct 25, 2009
Mother board doesn's recognized sound device, c-
I guess there is problem with drivers my be they are not properly installed.. For this Go to Control Panel ---> System ---> Hardware
---> Device Manager if you have any device marked with a question
mark or yellow admiration. See also Device Sound, video and games, to
see if the driver is installed.
if you got a Software CD with your system then it should have the
Audio Drivers. Just Reinstall it.
I hope it will help.
Thanks
9/25/2009 4:13:52 AM •
Matsonic...
Answered
on Sep 25, 2009
Intel Chip peplacement
according to the manufacturer:
Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~3.06GHz or faster Processor
Support Intel(R) Hyper-Threading Technology CPU
400/533MHz system interface speed
any socket 478 processor with a 400 or 533 bus speed should work.
7/23/2009 1:48:36 PM •
Matsonic...
Answered
on Jul 23, 2009
