20 Most Recent Motorola MH230R Two Way Radio Questions & Answers
Mh230r
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
9/10/2017 12:36:41 PM • Motorola MH230R ... • Answered on Sep 10, 2017
The back unit of charger will not charge radio?
common. The contacts are dirty most likely. Unplug the charger, get a small piece of fine or extra fine sandpaper and lightly sand the metal wires you see. They will bend, that is normal. So, slow and careful. Still not working? (also common). The charger base or the charger AC adapter may be bad. If you have another charger, switch the wall adapters. If the base if base, you could try to take it apart and re soldier it yourself, but if it got wet, the game is over. Go to a used donation place, such as the Goodwill to get replacements. They are not sold new without a radio. Also, try another radio in the "bad" charger, it could be the contacts on the back of the radio need cleaning.
2/17/2016 11:36:02 PM • Motorola MH230R ... • Answered on Feb 17, 2016
2answers
Just bought motorola 4 Talkabout MH230R they are working fine except for one which is only receiving the voice and not transmitting anything. I tried Ringing other Walkie Talkie and thats not working
is it water proof? did you dip it in water?... if you did that's why the mic isn't working, the call and mic isnt working make sure the channel is on the right channel for the walkie talkie
1/23/2016 9:13:02 PM • Motorola MH230R ... • Answered on Jan 23, 2016
Walkie talkie manual
http://shop.giantintl.com/Manuals.asp?offset=30
12/17/2015 12:23:37 PM • Motorola MH230R ... • Answered on Dec 17, 2015
One of 2 set Motorola MH230R isn't transmuting ring or voice, but receiving is fine. All settings the same. What's I am missing?
Check your batteries. Transmitting (Tx) takes more power than Receiving (Rx). Also, check to see if you have the Qt filter turned on, if so, turn it and all other special features off (zero) and try using the radios in a very basic mode. If you cannot Tx or Rx with good batteries, and all special features turned off, you have a problem with one of the radios.
10/17/2015 12:38:55 AM • Motorola MH230R ... • Answered on Oct 17, 2015
Just opened my new MH230R radios and the backlight function is only working on 1 of them.
Contact http://shop.giantintl.com/contact.asp
1/8/2015 4:08:01 PM • Motorola MH230R ... • Answered on Jan 08, 2015
Mh230r
Your radio is possible stuck in transmit, or has an internal issue. If you can get it into programming mode, check your programming. Also you might try trading the battery with a known good unit to see if it is simply a battery issue. Here's a link to the user guide: http://shop.giantintl.com/Manuals.asp Choose your model from the pulldown.
1/8/2015 4:02:46 PM • Motorola MH230R ... • Answered on Jan 08, 2015
Problem with ptt, i put it to speak but then they start over like when you turn it on
reset when transmitting is a sure sign of weak batteries
9/14/2014 7:27:17 PM • Motorola MH230R ... • Answered on Sep 14, 2014
The red light stays on when powers off
It is best to contact Motorola Solutions. portal motorolasolutions com Mark Motorola Mobility Support
9/14/2014 3:06:10 PM • Motorola MH230R ... • Answered on Sep 14, 2014
Why does Motorola MH230R two way radios shut off automatically?
It's best to contact Motorola Solutions. Http:www.motorolasolutions.com/support Mark Motorola mobulity
8/22/2014 4:20:34 AM • Motorola MH230R ... • Answered on Aug 22, 2014
Owners manual mh230R
Download from here: http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
8/2/2014 7:30:18 PM • Motorola MH230R ... • Answered on Aug 02, 2014
HOW DO I RESET BACK TO FACTORY SETTINGS?
There are no factory default settings. Just program each channel as you desire.
8/2/2014 7:10:14 PM • Motorola MH230R ... • Answered on Aug 02, 2014
Mh230r wont turn on
buy a new battery if not : these are one-way radios. no service, no spareparts. just trough away and buy new
6/11/2014 1:29:26 PM • Motorola MH230R ... • Answered on Jun 11, 2014
Static communication
Or you can adjust the squelch trimmer inside :)) There is always a solution ;)
4/12/2014 9:06:21 PM • Motorola MH230R ... • Answered on Apr 12, 2014
The red LED above the screen is always on when
The radio is not turning off completely. It is possibly a bad on/off, or it could be another button is slightly stuck and when turning the unit off it is trying to do another of the multi-button pressed functions. The on/off/volume potentiometer is a common failure item on most 2-way radios. Repeated use or dirt/dust/debris can cause it to fail. Do not use any solvents or cleaners. The best method of cleaning would be canned air. If you cannot find the way to clear the issue, your best option is to remove the batteries when not in use. Best regards.
9/7/2013 2:47:07 PM • Motorola MH230R ... • Answered on Sep 07, 2013
Only shows a red red screen when it turns on
Hi,Another made in CHINA toy radio.My advice buy a 2-way not made in china.Sorry for bad newsPeter
3/6/2013 6:18:01 AM • Motorola MH230R ... • Answered on Mar 06, 2013
My MH230R goes silent and then doesn't come on until I key the lime again
You could have a programming error, or a low/defective battery. Check your battery first. Trade batteries with a known good unit and see if the problem continues. If you still have the problem, it is a radio problem.Next try setting the radio back to a basic operation by turning off any special features such as Qt filter and Call Tones. These two items when not used properly, or mix-n-matched between radios can cause issues similar to what you are experiencing.Here is a link to the user guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/MH%20Series%20User%20Guide%20USA%2011-26-08%20KEM-PK14190-75.pdfBest regards.
8/23/2012 5:27:04 PM • Motorola MH230R ... • Answered on Aug 23, 2012
Motorola MH230R  Two Way Radio Logo
28 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
one 2 set motorola mh230r isnt
  • Radio Communications
