20 Most Recent
JVC Everio GZ-MG670 Hard Drive Camcorder Questions & Answers
WHen I try to format I get a now formatting
Hello Mr David Cannif
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
