20 Most Recent
HP DESIGNJET T1120 44 Printer Questions & Answers
Noisy on left side
Yes - but should not be THAT noisy maybe it is loose or is touching something inside.
Is the printer level on a solid base?
Check it all out first before rushing off down to your very friendly repair man
My Hp Designjet T1120 fails
Reset the formatter & check,,Hard disc
& main PCA any one of them faulty.. Through light pattern we can
estimate which part is faulty...Read carefully, understand the
indications..Led pattern: Power supply LED as 1Formatter leds 3nos from left to right as 2,3 & 4..* indicates "on"# indicates "off"& indicates "flashing"* # # # ....Main PCA* * # # ....Formatter* $ # # ....Hard disc* * * $ .....Main PCA or FormatterNote down which LED are on.off & flashing,compare with above said indications find out the faulty part..
Scan error starwheel axis
power off your printer, open your printer's left side, disassembly starwheel axis motor, clean the gears, re-plug all parts (if any part does not broken) , press up and enter buttons and hold, power on your printer, it will gets u in service mode, find "unlock carriage" and press ok, restart your printer.
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
