20 Most Recent Ricoh Aficio SP C231N All-In-One Laser Printer Questions & Answers
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Ricoh Aficio SP... | Answered on Mar 16, 2010
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer
Press C (Red colour centre) button once
Enter 107 (nothing will be shown)
Press the Green (Coping) button for 5 seconds
See the Display -->
Select Engine Maintenance
Select Ok
Select Fuse SC Reset (press down arrow - at down you will find it)
Execute (by Pressing the Down Arrow)
Done
Restart your printer.
Your problem should be solved....
Ricoh Aficio... | Answered on Aug 20, 2019
Check its connected to a network, the DHCP server is probably your router if you have a small or home network.
see
http://www.fixya.com/support/t25283562-solve_cannot_connect_dhcp_server_101#solution-section
Ricoh Aficio... | Answered on Jun 29, 2019
Probably, you will have to call your local Ricoh servicer for repair.
Ricoh Aficio... | Answered on Jun 27, 2019
Ricoh Aficio SP C231N All-In-One Laser Printer Logo
19 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
printer stopped printing gives error
  • Office Equipment & Supplies
