20 Most Recent
HP Deskjet D2660 All-In-One InkJet Color Printer Questions & Answers
How to reset printer HP deskjet D2660 all lights are blinking
Follow these solutions in the order presented to resolve the issue.
Solution one: Reset the printer
Press the Power button to turn on the product.
- With the product turned on, disconnect the power cord from the rear of the product.
Unplug the power cord from the wall outlet.
Wait at least 15 seconds.
Plug the power cord back into the wall outlet.
Reconnect the power cord to the rear of the product.
If the product does not turn on by itself, press the Power button to turn it on.
Solution two: Service the printer
Contacting HP for service in all countries/regions except Asia Pacific.
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to
HP's Warranty Check Tool .
If your product is in warranty, Contact HP to obtain service.
If your product is out of warranty, Contact HP to find an authorized service provider or to setup service (fees might apply).
Does my HP Deskjet D2660 mirror image print
HI,
I had this same issue until i went to Control Panel>Printers> right click on printer in question>Properties>under General tab click Printing Preferences>under Advanced Tab click Mirror Image off>just in case that wasn't going to cure my mirror image turning right back on I went to the Printing Shortcut Tab and re-saved my shortcuts, checking back to Advanced Tab to make sure that the Mirror Image still showed off. I've had no re-occurrence of that issue since.
Thanks,
HP Printer Support
How do i install or connect my printer on my PC
HP printers have come with an installation CD for as long as I can remember.
- Insert that CD into your computer,
- Start the installation (either via the auto start after you put the cd into your computer or manually browse to the setup file on the cd)
- Follow the steps of the installer and make sure you choose the correct options which apply to you.
Hope this helped!
Installer of d2660
please gave more details so can help you , what the wrong with installing are talking about software or toner , what the type of model Mohamed Hejazi HP TECH. SUPPORT AFAQNAMA Tripoli - Libya
Hp D2660 installer
Software and drivers for your printer can be found here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=uk&lc=en&dlc=en&product=3742936Hope this helps.
