20 Most Recent Lexmark X6675 All-In-One InkJet Printer Questions & Answers
Cartridge error message
Make sure you have the in the correct slots common problem I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
9/20/2017 2:02:10 AM • Lexmark X6675... • Answered on Sep 20, 2017
Scan document copy
epson 1390 service required problem
1/30/2014 11:09:26 PM • Lexmark X6675... • Answered on Jan 30, 2014
When I scan a document the image is too large.
try changing the "View" size. What application are you using in windows 8 to view the scan?
8/29/2013 6:08:18 PM • Lexmark X6675... • Answered on Aug 29, 2013
I can't find the auto answer light on the Lexmark X6675
To turn on the Auto Answer for fax, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering > Auto Answer > On.
9/11/2012 6:41:40 PM • Lexmark X6675... • Answered on Sep 11, 2012
Paper jam paper not being fed into the printer
open all access panels and check for paper jams....
9/6/2012 9:30:38 PM • Lexmark X6675... • Answered on Sep 06, 2012
Faxing problems
Check the scanner glass for ink or lint residue. This is what normally causes lines on faxed and scanned documents and pictures. Here is a link to explains it and shows where to check for the residue.http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
7/27/2012 8:06:04 PM • Lexmark X6675... • Answered on Jul 27, 2012
An error occured while printing
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
1/12/2012 6:32:53 PM • Lexmark X6675... • Answered on Jan 12, 2012
Scans partial images
The answer by printmaster is what I would have advised.
1/1/2012 10:50:01 AM • Lexmark X6675... • Answered on Jan 01, 2012
Lexmark x6675, saying missing color cartrige
Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
12/30/2011 4:20:10 PM • Lexmark X6675... • Answered on Dec 30, 2011
Paper jam, paper is jammed below roller cannot
Please try this approach to release the paper jam.
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Check the cartridge area for any obstructions in the paper path. Carefully remove the paper jam. Avoid tearing it or leaving torn pieces as it could cause future paper jams.
  5. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  6. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem si fixed.
12/27/2011 10:39:42 PM • Lexmark X6675... • Answered on Dec 27, 2011
Paper Jam on x6675???
In order to remove the paper jam, lift the scanner unit and you will be able to see the jammed paper. From there you can easily remove it.
10/17/2011 11:32:55 PM • Lexmark X6675... • Answered on Oct 17, 2011
Need to turn off ink
I regret to inform you that the "ink notification" cannot be disabled. The software is designed to remind you of your ink levels and avoid printing with empty cartridges. An empty cartridge has some serious disadvantages to the printer. It can lead to print quality issues.
10/3/2011 10:23:16 AM • Lexmark X6675... • Answered on Oct 03, 2011
Lexmark X6675 All-In-One InkJet Printer Logo
60 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
faxing problems
  • Office Equipment & Supplies
