20 Most Recent LG FB163 DVD/DivX USB Micro system Shelf System Questions & Answers
0answers
Hi I have the LG
This is caused by a weak poor signal strength or slow data transmission issues.
7/6/2017 7:56:18 PM • LG FB163... • Answered on Jul 06, 2017
No sound. only protection appear on sreen
Audio amplifier IC damaged need to be changed
1/4/2017 8:51:57 AM • LG FB163... • Answered on Jan 04, 2017
I have an LG fb163 everything seems to function but no sound in the speakers
check mute button, source knob/button, speaker selection knob/button while its playing a cd or FM radio. Also if you have connected headphones the speakers would mute. Check the speaker connections. If the speakers are powered you need to connect them to a power source. If all these fail to produce sound consult a technician.
10/31/2014 10:53:49 AM • LG FB163... • Answered on Oct 31, 2014
0answers
Lock stereo
Be the first to answer 4/1/2014 3:28:15 AM • LG FB163... • Posted on Apr 01, 2014Be the first to answer
0answers
Usb problem
Be the first to answer 1/26/2014 6:15:16 AM • LG FB163... • Posted on Jan 26, 2014Be the first to answer
2answers
How do i program my
Maybe we should start with the brand and model of your remote and find out what IT needs to know about the LG, hmm?
http://www.remote-codes.com/universalcodes.htm
7/16/2013 8:42:01 AM • LG FB163... • Answered on Jul 16, 2013
0answers
Lg fb162 region code locked
1. Press "On" on the unit 2. "No disc" will appear 3) Press "pause" on remote 4) Press "1472" 5) pressing "preset+" on remote five times go to the fifth group 6) edit the 5th number group in the code the first number is the region code eg. if the number is "12" then the region is set to 1 if the number is "42" then the region is set to 4 so if you want all regions set it to "02" by pressing 02 on the remote 7) when finished press "select/enter" 8) press "pause" again to exit from the menu 9) power off the unit and turn back on again.
1/17/2013 6:21:30 PM • LG FB163... • Answered on Jan 17, 2013
How do I get it to move on single MHz, at present it goes from say FM 98.50 to FM 98..55 Thanks
I don't think it would make a lot of differance if you did get it to move to say to 98.56 as most radio stations don't use anything smaller than XX.5 If you are trying to get a weaker station tuned in that is at the side of a more stronger station, then what you need is either a signal booster or a better aerial. Having said that the station might have the same frequency as the other station, because it's a local station to an area that you are just on the edge of it's range.
12/18/2012 5:43:08 PM • LG FB163... • Answered on Dec 18, 2012
I want to plug the
you will need rca leads, they are red and white, and go from the audio out on your tv to the audio in on your stereo which are colour coded red and white, if your tv and stereo are digital you can get a digital lead also
8/6/2011 1:00:14 AM • LG FB163... • Answered on Aug 06, 2011
Hi :) i was wondering
The answer is on pg 12 of the manual, which can be viewed here:
http://ebookspdf.s3.amazonaws.com/gadget/LG-FB163-Manual.pdf
Press clock for two seconds.
use the track forward and back to set the type (12 hr or 24 hr)..
press set.
use track forward and back to set hour.
press set
use track forward and back to set minute.
press set
7/1/2011 2:48:44 PM • LG FB163... • Answered on Jul 01, 2011
LG  FB163 DVD/DivX USB Micro system Shelf System Logo
Popular Tags
52 questions posted
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
no sound only protection appear sreen
  • Audio Players & Recorders
