20 Most Recent Onkyo Tx-sr507 A/V Receiver Questions & Answers
2answers
I have an Onkyo TX-SR507. I just hooked it up
Hello Katieandjona, My first & second guesses would be monitor & head-set modes... (possibly Zone 2 activated) ELSE... To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/ STANDBY] button (see page 93). Manual... page 5 http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr507_577_manual_e.pdf Hope this helps
9/13/2017 1:23:15 PM • Onkyo Tx-sr507... • Answered on Sep 13, 2017
Onkyo tx-nr515 no standby light,no power???
hi check the primary circuit for faulty fuse or the circuit is damaged needs servicing. good luck 24788689-piuz4ore2am3kwfxttudff4a-3-0.jpg
4/29/2016 5:40:49 PM • Onkyo Tx-sr507... • Answered on Apr 29, 2016
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
1/12/2015 11:35:55 AM • Onkyo Tx-sr507... • Answered on Jan 12, 2015
How to set up
From the receiver's remote control, press on the 'Source' or 'Input' button. On the list of A/V sources that comes up, you should see one entry for Apple TV and one for PS3, if you plug them in different ports.
12/29/2014 9:45:58 PM • Onkyo Tx-sr507... • Answered on Dec 29, 2014
0answers
How to take out of protective mode
You probably have a short in the amp. Should take in for a pro to look at.
5/28/2013 1:02:17 PM • Onkyo Tx-sr507... • Answered on May 28, 2013
My ts-sr507 Has blown,due to
You're in Canada...GOOD NEWS!
All in one electronics can fix anything Onkyo as they are the warranty repair location for Onkyo and a plethora of other big name brand electronics.
So in warranty or out, then can fix it.
send an email to Rob Tracy ([email protected]) and he can give you instructions on how to send it etc.
They are in Toronto, so shipping by UPS or FED-EX shouldn't be too bad.
I doubt he can give an over the phone estimate, but I can guarantee you that nobody will fix it faster or for less money because they probably have any and all parts in stock.
8/30/2011 8:20:38 PM • Onkyo Tx-sr507... • Answered on Aug 30, 2011
Turn the unit on screen displays PROTECT then
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
8/25/2011 11:40:03 PM • Onkyo Tx-sr507... • Answered on Aug 25, 2011
Hi I have just connected my onkyo tx-sr 507
The 'monitor' video output would go to a corresponding composite video input on the TV/monitor. It would be selected as a source, not a channel. I'm sure the unidentified video device's manual explains it. Any RCA cable would suffice.
8/9/2011 2:37:46 AM • Onkyo Tx-sr507... • Answered on Aug 09, 2011
2answers
All plugged in but no pictures to tv
Bypass the video / audio of the DVD to the TV and see if the input works on the TV. If so the connection of the home theater must be checked once again.
Connect the video and audio correctly and switch to the same function connected in the rear panel. If there is no video or audio or one of them then the digital logic switching circuit can be faulty. Since most of the selection is done through LOGIC GATES this IC could have failed.
You will need to use a logic tester to trace and confirm if the rest of the amp works fine.
Also try changing the input ports.
7/27/2011 12:38:59 PM • Onkyo Tx-sr507... • Answered on Jul 27, 2011
I have a onkyo tx-sr507
A simple composite video connection from its Monitor Out to the appropriately-selected input on your TV may resolve that.
Or, from the manual...
"While the Pure Audio listening mode is selected, the video circuitry is turned off and only the HDMI OUT outputs video signals."
7/13/2011 10:26:26 AM • Onkyo Tx-sr507... • Answered on Jul 13, 2011
Question: is there a usb
Onkyo SR >> X << 507?? No such animal according to Google.
How about TX-SR507?
http://filedepot.onkyousa.com/Files/own_manuals/SN29344940A_TX-SR507_577_En_web.pdf
No USB.
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO).
Get a cable like the one described here: http://www.monoprice.com/products/product.asp?
c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
5/15/2011 11:33:00 PM • Onkyo Tx-sr507... • Answered on May 15, 2011
I have tried all DirecTV codes on my Onkyo
If you still have the direct tv remote you can make the onkyo learn the codes from the direct tv remote via the Learning mode on the Onkyo Remote.Consult the onkyo remote user manual on how to do this step by step.This applies to remotes that have the learning feature,not all remotes have this feature,consult the manual to see if your remote has this feature.Good Luck
2/12/2011 2:47:50 AM • Onkyo Tx-sr507... • Answered on Feb 12, 2011
No video when connecting wii to Onkyo TX-sr507 AUX
Did resolve the issue? I 'm pkanning to buy wii @ my home. Please suggest me.
I do use the Onkyo 507.
9/26/2010 12:42:25 PM • Onkyo Tx-sr507... • Answered on Sep 26, 2010
Onkyo Tx-sr507 A/V Receiver Logo
57 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
onkyo tx nr626 when volume high like 70
  • Audio Players & Recorders
