20 Most Recent Onkyo TX-SR876 Receiver Questions & Answers
Fm stereo stopped working; no stereo beacon, no sound
Hi... try factory reset: while holding down VCR/DVR button ,press the ON/STANDBY button. "Clear" will appear on display ,and receiver will enter standby mode. :)
1/27/2014 12:03:19 AM • Onkyo TX-SR876... • Answered on Jan 27, 2014
Brand new. No sound from any speakers or
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
8/12/2013 12:49:43 PM • Onkyo TX-SR876... • Answered on Aug 12, 2013
0answers
0answers
Ht-r990 3d
Be the first to answer 3/30/2012 4:03:55 AM • Onkyo TX-SR876... • Posted on Mar 30, 2012Be the first to answer
0answers
Lost power for 30sec audio
Reset the amp Press VCR/DVR and them power. once you see CLEAR on the screen. press power
11/27/2011 5:30:33 AM • Onkyo TX-SR876... • Answered on Nov 27, 2011
Sceen on tv freezes
Open the cover and place a fan on top of the HDMI board. most likely this will be the cause since most issues with onkyo are related to heating.this should do it.or try to reset the HDMI Board, HOLD BD/DVD button and press power bottom it will give you an option to disabe the HDMI card. it that does not work contact me I can give you the steps to run the ONKYO diagnostics it's conbination of keys that will give you about 50 diferents tests to perform.
11/27/2011 5:17:37 AM • Onkyo TX-SR876... • Answered on Nov 27, 2011
My television picture does not appear on my zone 1
Hi. Most likely the assigned input isn't correctly setup. Try this:
1. Press 'setup' on your remote control.
2. Navigate to 'Input Assign'.
3. Navigate to the correct next option (HDMI/Component/Digital) - this depends on how you have connected your DVD player up.
4. Find the name of the connection you've plugged your DVD into (physically look at the back of the receiver).
5. Select the DVD option, and press left/right until you have selected the correct input.
You may need to change to Tuner then back to DVD, but that should do it.
If you need further help, please let me know exactly how you've connected your DVD player (HDMI? component?), and the name of the physical connection you've plugged into.
Hope that helps!
3/4/2011 11:18:44 PM • Onkyo TX-SR876... • Answered on Mar 04, 2011
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update. Try resetting the receiver's BIOS by following these steps2: Unplug all cables Un-Power the receiver Power the receiver Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration. Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power. TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
2/26/2024 3:51:06 AM • Onkyo Audio... • Answered on Feb 26, 2024
2answers
Onkyo nr 555 stuck on recovery:NET
Hello Did you update the AVR over the internet? If so the device wont work anymore. You need to service the device in a nearest Onkyo service department. Regards
2/24/2024 6:24:24 PM • Onkyo Audio... • Answered on Feb 24, 2024
3answers
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
1/2/2024 2:06:41 AM • Onkyo Audio... • Answered on Jan 02, 2024
Part number of battery on onkyo digital board for TX DS-797
Here is service manual for your help. See the pat reference on IO Board and compare it with service manual. ONKYO TX-DS797 SERVICE MANUAL Pdf Download ' ManualsLib
12/31/2023 9:27:34 AM • Onkyo Audio... • Answered on Dec 31, 2023
Onkyo TX-SR876 Receiver Logo
19 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
fm stereo stopped working no stereo
  • Audio Players & Recorders
