20 Most Recent Plantronics Explorer 230 Bluetooth Headset Questions & Answers
How can I pair it with laptop?
Wendell, is lap top also blue tooth. First you need to turn Bluetooth on in your laptop. Begin with the headset off, now press and hold the control button for approximately ten seconds(led will flash blue). Continue holding button until led flashes red then blue, release button. Headset is now in Pairing Mode. Laptop should be able to find it. If Pass key is required, default is 0000. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2/28/2016 2:13:47 AM • Plantronics... • Answered on Feb 28, 2016
0answers
Not charging
Be the first to answer 4/10/2014 3:02:46 AM • Plantronics... • Posted on Apr 10, 2014Be the first to answer
0answers
2answers
My explorer isnt doing anything.. the led is solid
The headset must be put into pairing mode. Once you make your phone discoverable, then put the Plantronics 230 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Here is a link for the pairing instructions for the 230 headset:Plantronics Explorer 230 Pairing InstructionsGood luck from Headsets Direct!
12/8/2012 3:04:01 PM • Plantronics... • Answered on Dec 08, 2012
2answers
Need manual for LG HDM 230 Bluetooth
Here's the user guide for the Explorer 230:Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
4/19/2012 10:41:16 PM • Plantronics... • Answered on Apr 19, 2012
Can not find passkey
For all current Plantronics bluetooth phones, the passkey is four zeros (0000).Good luck from Headsets Direct!
11/30/2011 8:10:32 PM • Plantronics... • Answered on Nov 30, 2011
How do i turn off the blinking led light?
Below is the link for the Explorer 230 user guide. See Headset Controls in the user guide. Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/30/2011 5:27:46 PM • Plantronics... • Answered on Nov 30, 2011
How do you turn off the led indicator light?
Below is the link for the Explorer 230 user guide. See Headset Controls in the user guide.Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/30/2011 5:26:00 PM • Plantronics... • Answered on Nov 30, 2011
My bluetooth head set is pared with my phone. It
Delete the headset from your phone. Turn your phone and headset off. Turn your phone back on and follow the directions to pair the headset to your phone. I will include a link to the user guide below.Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/30/2011 5:24:23 PM • Plantronics... • Answered on Nov 30, 2011
When I hit the button on my blue tooth it sends my
It almost sounds like you are rejecting a call, and when that happens you will send it to voice mail. It says that if you are tapping twice, it will sens it. I am also giving you the link to the users guide below to try and help.Plantronics Explorer 230 User's GuideIf this does not work please refer to Plantronics tech service, 800-544-4660 ext 5538.Good luck from Headsets Direct!
11/29/2011 11:21:21 PM • Plantronics... • Answered on Nov 29, 2011
My plantronics explorer 230 is
If your phone has a bluetooth application it should pair up to it. I will send you the user guide to hook it up properly.Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/29/2011 11:17:56 PM • Plantronics... • Answered on Nov 29, 2011
Im having a hard time
Here are a couple of things to try. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Then reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and then page 4 will walk you through the pairing process. Remember to remove any lingering bluetooth connections from your phone.Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/29/2011 11:16:45 PM • Plantronics... • Answered on Nov 29, 2011
Trying to connect bluetooth to
The pass code should be 0000 (four zeros), it's always been that for Plantronics headsets. Here are a couple of things to try. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Second, you want to reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and page 4 will walk you through the pairing process. Remember to remove any previous bluetooth connections from your phone.Plantronics Explorer 230 User's GuideGood luck from Headsets Direct!
11/29/2011 10:44:41 PM • Plantronics... • Answered on Nov 29, 2011
I have a att quickfire trying to get my
Make sure the headset is off when you start the pairing process for linking it to your phone. Then see your phones user guide for linking the headset. Good luck from Headsets Direct!
11/29/2011 6:04:08 PM • Plantronics... • Answered on Nov 29, 2011
I have a explorer 210 headset .After a call I am
I would suggest deleting the headset from your phone. Turn your phone and headset off. Turn your phone back on and follow the directions to pair the headset to your phone. I will include the link to the user's guide below.Plantronics Explorer User's GuideGood luck from Headsets Direct!
11/29/2011 5:37:53 PM • Plantronics... • Answered on Nov 29, 2011
Plantronics Explorer 230 Bluetooth Headset Logo
Popular Tags
106 questions posted
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Plantronics Radio Communications
Most Popular Question
explorer isnt doing anything led solid
  • Radio Communications
