20 Most Recent Sanyo VPC-CG10 High Definition Camcorder Questions & Answers
Manual xacti cg10
You can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/product/Downloads/VPC-CG10_OM_English-33168772.pdf
8/14/2011 11:01:09 PM • Sanyo VPC-CG10... • Answered on Aug 14, 2011
Hi. While shooting a video, the recording is too
Please check and adjust your white balance in sub menu. You can use trial and error method to get the best video appearance and delete the bad videos from camera memory.
12/22/2010 2:31:27 PM • Sanyo VPC-CG10... • Answered on Dec 22, 2010
Asking for formating memory card, after formating
Usually the process of formatting memory cards wipes off all information on a memory card. If after formatting the cards shows problem with memory card then the memory card has bad sectors which make the card no longer usable.
Bad sectors in a memory card are usually caused by poor storage of information and viruses. Best solution will be to replace the card but if not connect the card to a PC and defragment this will seperate the bad sectors from the good ones. Although you will not have full use of the card size.
Hope this solution has been helpful?
12/21/2010 11:05:53 AM • Sanyo VPC-CG10... • Answered on Dec 21, 2010
When i convert videos into my laptop videos are in slow motion
The NV3 uses a modified XviD MPEG-4 file format, and nearly every video you want to view on your camera has to be converted to that format with the included software.
3/1/2010 2:42:38 AM • Sanyo VPC-CG10... • Answered on Mar 01, 2010
My Sanyo Xacti VPC CG-10 HD Dual Camera is broken
its could be but if your tech you can fixed,
if not
you better see a technician whit experience
its the best i can tell...
2/7/2010 8:37:53 PM • Sanyo VPC-CG10... • Answered on Feb 07, 2010
Good day.i just received a present and it's a
Here is a screen shot of the menu you should see when you turn it on set it to normal mode and press the menu button, in english instead of the japanese you are seeing. I am hoping for your sake the menus are laid out the same way and only the words or characters are different.
Scroll down to the second wrench, select the second from the bottom, and press SET. English should be the first option at the top of the next screen. Highlight the first option and press SET.
I uploaded the manual of this camera to fixya, though it may not turn up for a day or two due to processing.
Look through my other posts for this camera and you will find the link to the cameras manual online elsewhere.
I hope that helps.
10/11/2009 3:23:13 AM • Sanyo VPC-CG10... • Answered on Oct 11, 2009
Where do I find the software for use with sanyo
www.myacrobatpdf.com/.../sanyo-software-pack-75-for-digital-movie-camera-instruction-manual.html
search.wareseeker.com/sanyo-xacti/
8/25/2009 5:01:26 PM • Sanyo VPC-CG10... • Answered on Aug 25, 2009
0answers
Sanyo VM-EX220P 8mm Video Camera. Hello my camera won't play any of my cassettes. It all comes up scrambled?!
Question edited for a lot more clarity. Question moved from Televisions category. When was the last time the head was cleaned? It may also need servicing or Adjustment.
Sanyo VM-EX220P Adjustment Manual
https://www.manualslib.com > ... > VM-EX220P View and Download Sanyo VM-EX220P adjustment manual online. 8 mm. VM-EX220P camcorder pdf manual download. Also for: Vm-ex370p, Vm-ex280p. ..
6/26/2023 6:37:46 PM • Sanyo Video... • Answered on Jun 26, 2023
Hi i have a sanyo hi 8 camcorder 25 plus years old and it loads and ejects and tape flashes continually whats the oroblem
It sounds like your Sanyo camcorder may be experiencing a problem with the loading or ejecting mechanism. This could be caused by a number of issues, including a damaged or broken cassette mechanism, a malfunctioning loading or ejecting motor, or a problem with the camcorder's control board. To troubleshoot the issue, you could try the following:
  1. Make sure the camcorder is clean and free of any debris or obstruction.
  2. Check the cassette for damage, such as broken or bent spindles, and make sure it is properly seated in the camcorder.
  3. Try using a different cassette to see if the problem persists.
  4. If the problem persists, you may need to have the camcorder repaired by a professional.
Keep in mind that due to the age of your camcorder, it may be more cost-effective to purchase a new one rather than repair the old one. However, if the camcorder has sentimental value or is no longer in production, repair may be the best option.
1/2/2023 6:16:38 PM • Sanyo Video... • Answered on Jan 02, 2023
Sanyo VM-D66P error: CASSETTE
There is a pulley that breaks inside but as these have been obsolete for over 20 years, I doubt it is repairable any more. Fully working VM-D66p for £30 on amazon or fleabay.
2/3/2022 1:35:20 PM • Sanyo Video... • Answered on Feb 03, 2022
Hello, I have a sanyo vm d66p camcorder and want to play it through a tv. What cables do I need ? thanks in advance
You need the RF Adapter cables. I have seen items like that at thrift stores. The camera has that barrel connector with 6? pins to connect it to the converter box that output to Channel 3-4. Keep checking ebay or craigslist. https://www.manualslib.com/manual/894346/Sanyo-Vm-D66p.html?page=2#manual https://www.ebay.com/itm/Sanyo-VM-D6P-8mm-Video-Camera-Bundle/163512488835?hash=item26121a9383:g:pLYAAOSwUMBb8MfJ:rk:1:pf:0
2/6/2019 4:14:21 AM • Sanyo Video... • Answered on Feb 06, 2019
0answers
Sanyo VPC-CG10 High Definition Camcorder Logo
21 questions posted
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
VPC Sanyo
  • VPC Sanyo
Most Popular Question
manual xacti cg10
  • Video Cameras
