You need an editing program, and then you will transfer the files from within the program ...
This camera stores the video using a unique method, and does not allow
you to simply drag and drop the video files - you also can not easily
find the camera and play the video real time to transfer it ...
You
need a compatible software program, meaning the software needs to be
compatible with the camera ... there are many available ... but if you
are looking to buy software check to see if it is compatible with your
camera before purchasing ... I wonder, what software will you be using
to edit the video?
For example, you can use Final Cut Express. It
will find the camera as long as the camera is connected via USB and
there is power applied to the camera ... once connected, look at the
camera LCD screen and select "Computer" for the connection ... then, in
Final Cut Express, select Log and Transfer (File menu), and you will get
a new window. You camera should be recognized and you can select the
video takes that you want to transfer and then hit "add selection to
queue" and the transfer will begin.
You will first want to check in
Final Cut Express where the transfers will end up on the computer, and
pick a suitable location with plenty of hard drive space (Final Cut
Express menu / System Settings / Scratch Disks) so you can find them if
you want to at some point in the future.
Assuming you will be
editing in Final Cut Express, you won't actually need to find them, but
its important to select a scratch disk location that has plenty of hard
drive space, and if you want to copy one of the clips to use it directly
to just upload to YouTube or something like that, you'll know where
they are (they will be .mov files, and can play all by themselves using
Quicktime or any similar program)
As always, refer to the manual
if you run into any problems ...
Hope this helps!
See our
latest DVD on PA systems, avoiding feedback and echo, and great AA Conference Speaker Tapes and CDs at
www.whamuniversal.com
