20 Most Recent Sony CRX880A CD-RW/DVD-ROM Combo Drive Questions & Answers
My Sony CDRWDVD CRX880A ATA
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
7/3/2011 6:50:44 PM • Sony CRX880A... • Answered on Jul 03, 2011
My Sony Combo Model CRX320AE
Try a different CD/DVD
1. First we must determine if the cd/dvd or the cdrom itself has a defect 2. Try at least 10 cds to test on your cd/dvd player
Try Deleting LowerFilters / UpperFilters
To do this follow the steps below:
1. Click Start -> Run (for XP) or Start Search (Vista) or search for programs and files (Windows 7)
2. Type Regedit
3. Click on the plus sign beside HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
4. Under Class Click on the Folder {4D36E965-E325- ....} (note that the alpha numeric numbers are quite similar we only need ....65)
5. Look for UpperFilters and Delete it
6. Look for LowerFilters and Delete It
7. Restart the computer
If it did not work try
Replacing the IDE cable
1. Open thechassis of the computer (refer to your computer manual) 2. Try disconnecting and reconnecting the gray cable that looks like a belt at the back of the computer
5/29/2011 9:46:40 AM • Sony CRX880A... • Answered on May 29, 2011
2answers
Drive not recognized driver missing or currupt
a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
3/15/2011 10:58:27 PM • Sony CRX880A... • Answered on Mar 15, 2011
Sony crx880a cd-r/rw/dvd-rom drive won't do
Please go ahead and click on start > in start search type in device manager {(in vista ) in case of xp right click on my computer > properties > hardware > devicemanager}.
In device manager click on the + sign beside the cd- dvd > then right click on the driver and uninstall it .
Then in start search type in regedit {(for vista ) for xp in run type in regedit}
Look for some thing like
HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then on the right hand side look for something like upper and lower filters and delete the upper and lower filters....
Restart the notebook . It will help
9/6/2010 5:28:43 PM • Sony CRX880A... • Answered on Sep 06, 2010
My cd/dvd sony crx880a drive stopped working
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. G
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
11/21/2009 4:57:08 AM • Sony CRX880A... • Answered on Nov 21, 2009
0answers
Sony MHC-vx888 turn volume up sound disconnect
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
10/20/2013 2:05:40 AM • Sony CRX... • Answered on Oct 20, 2013
Cant get on sony acid music studio 5.0 cause i dont have my serial number anymore please help
We can't helpwith that but you could contact your software supplier and ask for a copy.
4/10/2024 11:55:56 AM • Sony Computers &... • Answered on Apr 10, 2024
Sony Vaio PCG-9S1L. Can anyone upload the owner manual. Thanks
Question edited for clarity, and toss in CAPS. Duplicate question deleted. Refresh page to see your question. Whatever you are trying to do with this Mr Chan, you are wasting your time. It is a Vintage computer running Windows 7. The manual is here
Sony VAIO PCG series Manuals
ManualsLib https://www.manualslib.com > ... > Laptop We have 1 Sony VAIO PCG series manual available for free PDF download: User Manual. Sony VAIO PCG series User Manual (202 pages). https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual ....
4/6/2024 7:02:02 PM • Sony Computers &... • Answered on Apr 06, 2024
Sony VRD-MC1 DVD RW Dual Layer. I have been using it many years, but have problems. What do I have to do now please?
Question edited for clarity and made into written English. If you got 6 to 10 years use, you just buy a new one for $15.97. https://www.google.com/search?q=Sony+VRD-MC1+DVD+RW+Dual+Layer ..
10/26/2023 1:10:51 AM • Sony Computers &... • Answered on Oct 26, 2023
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off. These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
9/18/2023 2:00:07 PM • Sony Computers &... • Answered on Sep 18, 2023
Where can I get Sony Control Cables needed for ST-S101 & TA-F101r?
Depending on your location. You have to go to a computer accessories closest to you. Yes you can definitely get it.
7/22/2023 7:40:47 PM • Sony Computers &... • Answered on Jul 22, 2023
Sony sound forge pro 11.0 serial number
Magix can supply you with that.
SOUND FORGE Pro - Download music editing software free
Magix https://www.magix.com > music-editing > sound-forge... SOUND FORGE Pro enables professional audio editing at the highest level. Download the music editing software now for free! ..
7/9/2023 6:13:23 PM • Sony Computers &... • Answered on Jul 09, 2023
I need an amplifier board for my Sony HCD-GNV111D / MHC-GNV111D
this is a question and answer forum manufacturers do not read this forum. You may want to look on eBay or other places that sell parts.
6/28/2023 3:26:24 PM • Sony Computers &... • Answered on Jun 28, 2023
Sony Vaio VGC-LM1E Recovery reinstall
Windows Vista Home Premium? It is an antique, throw it out! That is the most hated version of Windows ever produced. Your old hard drive has an embedded serial number and that is part of the credentials used to load your original copy of Windows and authorize the copy. However, that should come later when you enter the Product ID did you format the hard drive first? format C:\ /s if I remember correctly at CMD Prompt Your question is at Tom's Hardware! https://www.google.com/search?q=Sony+Vaio+VGC-LM1E+install+and+format+hard+drive ..
5/30/2023 8:30:03 PM • Sony Computers &... • Answered on May 30, 2023
Why can't Alexa change my TV channel with Sony Basic TV app?
Not sure who you are talking to in the 'Additional Information' box below your question. You may have be talking to an AI Answer Bot which has had its answer deleted. That box up there is for Experts to ask you for further information before committing to an answer. The correct way is to click Comment under the Answer you are replying to. Sony seems to think it can be done.
Connect your TV to the Amazon Alexa app
Sony https://www.sony.ca > electronics > support > articles On the Amazon Alexa app: Open the Amazon Alexa app on your smartphone, search for BRAVIA, and then select Sony's TV - Basic Skill and enable it. Note: If you ...
FAQ - Control your TV with Amazon Alexa devices
Sony https://www.sony.com > electronics > support > articles For TVs with the TV Control Setup with Amazon Alexa app: Select the Sony's TV - Basic skill, and enable it. Alternatively, you can also enable it by ...
5/16/2023 4:39:29 PM • Sony Computers &... • Answered on May 16, 2023
2answers
Need to reset password for SONY VAIO PCG-7142L.
Solved - password reset or removal
Vista Forums https://www.vistax64.com > ... > General Discussion Its a Sony laptop with a windows vista home premium OEMAct, model pcg-7142l . I don't know if it is a bios or vista password.
How to remove the log in password.
Sony https://www.sony.com > electronics > support > articles Nov 17, 2016 - Refer to the operating instructions supplied with the computer for model-specific information required to complete a format and recovery ...
How to Reset Password on Sony Vaio Laptop Windows 7/8 ...
PassCope https://www.passcope.com > how-to-reset-password-o... Here, we are going to specify how to reset the password on Sony Vaio laptop using various alternatives for Windows 7/8/8.1/10.
5/9/2023 8:17:20 AM • Sony Computers &... • Answered on May 09, 2023
Sony CRX880A CD-RW/DVD-ROM Combo Drive Logo
Popular Tags
9 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
sony cdrwdvd crx880a ata
  • Computers & Internet
