20 Most Recent
Gateway LX6820-01 Desktop PC Questions & Answers
Upgrading to windows 7
When you first boot from the win 7 disc there is a option to format or delete a partition.Do both.This will erase all vista information and allow only win7 to be installed.
4/22/2016 6:30:13 AM •
Gateway...
Answered
on Apr 22, 2016
How to connect a cd rom/dvd
If your CD / DVD is powered on Ok then you are missing the data cable connection which will be either a SATA (small connector) or IDE (much larger connector) both of which plug in to your motherboard....Look at the CD / DVD and try to identify which type of connector you are missing then look for an unconnected cable of the same type within your case.
12/17/2011 2:11:38 PM •
Gateway...
Answered
on Dec 17, 2011
Hi there
i need an assistant,
If your desktop goes to sleep when it is idle, then this is controlled by your power settings and you can change the time for how long the system can be idle before going to sleep....If pressing a key or moving the mouse does not wake the system again, then try just pressing once on the power button which should cause the system to wake and bring you back to a sign-on panel again. Note: do not press and hold the power key as this will force power off if held for more than 4 seconds normally on most systems.
12/17/2011 1:39:28 PM •
Gateway...
Answered
on Dec 17, 2011
SHATTING DOWN BY ITSELF EVERY 5-10 MIN
I am sure you mean it is SHUTTING down.
This usually an overheating problem.
Open up the computer and clean out the fans, if you google cleaning my computer, there are lots of guides and youtube video's
7/26/2010 3:21:58 PM •
Gateway...
Answered
on Jul 26, 2010
High temperature sensor
It's possible, but before I did anything with that, Have you ever vacuumed or used canned air on the vents and fan assembly? Dust blockage could cause overheating.
12/22/2009 2:15:48 AM •
Gateway...
Answered
on Dec 22, 2009
Looking for motherboard manual for G45T/G43T-AM3
Motherboard Manual for EliteGroup G45T-M2 (Version 1.0A),
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=912&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Scroll to the bottom of the page to the heading - Manual for G45T-M2 (V1.0) Click on the country nearest you.
Motherboard Manual for EliteGroup G43T-M3 ver1.0
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=965&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
(What's with the AM3 listed? The G45 is an Intel motherboard chipset, as well as the G43)
11/15/2009 5:57:20 AM •
Gateway...
Answered
on Nov 15, 2009
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
