20 Most Recent LG WM2301HW Front Load Washer Questions & Answers
LG Model #WM2301HW (2010 model year) The issue we have had; occasionally there seems to be dirt marks on our clothes. I would say this happens 2 of every 50 loads. LG says this is due to a trap that n
The drain hose is down too deep into the drainpipe causes some backflow of dirty waste. Needs air gap for atmospheric pressure and gravity do the draining, so the drain hose is down from 4" to max 7" into the stand drain.
1/8/2019 5:43:18 PM • LG WM2301HW... • Answered on Jan 08, 2019
2answers
LG washing machine loud and
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
9/12/2018 7:27:39 AM • LG WM2301HW... • Answered on Sep 12, 2018
Large loads won't balance & spin
Could be: 1. Broken spring(unlikely) 2. Bad shock absorbers (maybe) 3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely. Good luck
3/8/2018 5:10:52 AM • LG WM2301HW... • Answered on Mar 08, 2018
Everything was going fine with the laundry. Took
not sure if you did this already but unplug it for 10 Min and see if it does a reset. for your reference in case it doesn't help..... https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/46-200-866280-/new/LG-Washer-won-t-start-WM2701HV hope this helps a little.
3/8/2018 5:01:40 AM • LG WM2301HW... • Answered on Mar 08, 2018
I have to flip the breaker after each load
this could be a short in the windings of the pump or motor
3/2/2018 9:38:16 PM • LG WM2301HW... • Answered on Mar 02, 2018
I recently purchased an LG WM2301HW washing
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
4/11/2017 10:25:04 AM • LG WM2301HW... • Answered on Apr 11, 2017
I have an LG WM
Rubber seal on the bearings going bad.
3/8/2017 6:07:12 AM • LG WM2301HW... • Answered on Mar 08, 2017
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
3/19/2016 8:29:42 PM • LG WM2301HW... • Answered on Mar 19, 2016
Our LG washer keeps going through noise filters. Last 2 times has been during early spin cycle of wet bulky load of sheets. Can't think of how vibration would blow built in fuse in filter??
Is your AC supply very stable? The manufacturers repair manual states that the AC supply of 120V may only fluctuate +10% or -15%
6/8/2015 3:07:13 PM • LG WM2301HW... • Answered on Jun 08, 2015
Grease like stains on clothing after washing
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
1/1/2015 1:56:17 AM • LG WM2301HW... • Answered on Jan 01, 2015
Washer stopped mid cycle and now it will not even turn on. I can also smell a burnt odour. Is my motor shot?
Yes, the motor has definitely burnt out causing an overload protection to switch off the electrical supply inside the machine.
9/28/2014 8:23:07 AM • LG WM2301HW... • Answered on Sep 28, 2014
0answers
Ecl lock error
Be the first to answer 1/15/2014 3:32:42 AM • LG WM2301HW... • Posted on Jan 15, 2014Be the first to answer
0answers
LG WM2301HW Front Load Washer Logo
109 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
grease like stains clothing after
  • Washing Machines
