20 Most Recent
LG enV Touch VX11000 Cell Phone Questions & Answers
LC VX-11000 Dead Outer Touch Screen - Can it be Fixed?
Odds are it may have completely dried out, but left corrosion behind. Replacing the digitizer would not fix the problem, in my opinion. You can buy a used handset for less than $100 online.
The reason I say to replace it is because f you could find someone to replace the digitizer, which the part lists for about $20 online, then you $$ for labor, and it might not fix it, it would be cheaper in the long run to buy another handset.
Again, just my opinion.
I dropped my Phone
yes you can. There is a company in denver , co that does repairs called wireless image. You can contact a local repair center or any cell phone place that does repairs will do it for you.
Ok every time my phone says low battery i go and
Your phone's battery has most likely reached the end of its life. Luckily, replacement batteries for the enV Touch are very inexpensive. Here's a battery that will work with your phone, for $8.00, and free shipping. I am not affiliated with the seller.
http://cgi.ebay.com/NEW-OEM-LG-LGLP-AHLM-EnV-TOUCH-VX11000-VX11k-BATTERY-/260745505647?pt=PDA_Accessories&hash=item3cb5a4ab6f
Cant find serial number
look underneath the battery, there should be a paper label there with several numbers on it. It should be labeled as S/N or ser.
