verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Question edited for clarity.
Question moved from Computers category.
Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power.
https://www.google.com/search?q=lifesmart+ls350+plus+220+volt
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need.
That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on.
Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard.
https://www.google.com/search?q=Maax+461+Heater
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out.
So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
Question edited for clarity, spelling of maker and order of 'make model (what it is)'.
Question moved from Sewing Machines category.
It appears to be a New Zealand product made in Australia. We are in North America. This link should find you one and also has a link to the maker.
https://www.google.com/search?q=+leisurerite+GL2000+spa+replacement+cover
if your hot tub is tripping the breaker, it could be due to a worn out ground fault circuit interrupter (GFCI) breaker, which is responsible for preventing electrical surges. You can try flipping the breaker to see if it trips again. If it does, then you may need to replace the breaker.
Another possible cause of the problem could be loose electrical connections in your hot tub . This can lead to power fluctuations that cause your hot tub circuit breaker to trip. Professional electricians can inspect your hot tub and tighten any connections that are loose, which should fix the circuit breaker problem.
If your spa is not receiving power, you should check your home's circuit breaker to ensure that it's not tripped . Reset the circuit breaker if it's tripped to restore power to the spa. If the circuit breaker keeps tripping, it may be an indication of an electrical problem, and you should call a professional electrician to diagnose and fix the issue
According to the South Seas Spas Owner's Manual, the filter cycle begins 6 minutes after the spa is energized and the second filter cycle begins 12 hours later. The filter duration is programmable and can be set to 2, 4, 6, or 8 hours for continuous filtration (indicated by "FC"). The default filter time is 2 hours.
It's possible that your filter cycle duration is set to continuous filtration mode. To change the mode, press the "Warm" or "Cool" button and select a duration of 2 hours.
If this doesn't resolve the issue, it's recommended to contact a professional technician for further assistance.
On the control unit select the 'up' arrow to cycle through the LED lighting options. Some units will only have one option (Blue) while other models will have a spectrum of colours to select from. Control unit diagram illustrated here https://www.hottubhiremerseyside.co.uk/faqs/
