20 Most Recent
Nortel Networks SR1004 4P ACTIVE T1 10/100 ETH INCL NA PWR Router Questions & Answers
I have a nortel tasman 1004 with 1 t1 port
Here are some commands to configure your tasman router :tasman> sh configuration runn Please wait... (up to a minute) terminal exit terminal qos exit qos module t1 1 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 module t1 2 clock_source line alarms thresholds exit thresholds exit alarms linemode exit linemode exit t1 interface ethernet 0 ip address 66.201.12.x 255.255.255.0 <------- for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 0.1 ip address 62.18.3.0 255.255.255.0 <------ for example ip multicast ospfrip2 icmp exit icmp qos exit qos vrrp_mode 0 exit ethernet interface ethernet 1 icmp exit icmp qos exit qos exit ethernet interface bundle MFR1 link t1 1 link t1 2 encapsulation frelay fr intf_type dte frame_size 4470 mfr fragment_size 4000 mfr seg_threshold 3999 lmi ansi exit lmi pvc 500 shaping cir 3072000 bcmax 3072000 bcmin 65536 no policing ip address 15.10.16.86 255.255.255.252 <------ WAN IP address to ISPicmp exit icmp red exit red exit pvc exit fr icmp exit icmp qos exit qos exit bundle aaa radius exit radius exit aaa snmp system_id tasman1 enable_trap exit enable_trap exit snmp hostname tasman telnet_banner exit telnet_banner event exit event system logging syslog exit syslog exit logging ip load_balance per_flowroute 0.0.0.0 0.0.0.0 15.10.16. 85 1exit ipfirewall globalalgsexit algsmax-connection-limit self 2048exit firewall firewall internetexit firewallfirewall corppolicy 1024 out permitexit policyexit firewallpolicy community_list exit community_list tasman> Or use the link below:
http://www.ipbalance.com/vendor/tasman-networks/454-mlfr-boundle-serivce-configuration-for-tasman1004-router.html
Need to reset, but don't
That model isn't familiar to me, but try default login ID "admin" and Password "setup". If that doesn't work, the following procedure might allow you to log on and delete the config. That will delete everything, though, so make sure you read out all the configuration info before you reset.
- Connect the Console cable to the Console port on the Secure Router
- Connect the other end of the DB-9 Console cable to the COM-1 port on the workstation
- Start the Hyper terminal (VT-100 or equivalent) application on PC-1
- Configure the COM1 port for 9600 bps, 8 data bits, 1 stop bit, no parity, and XON/XOFF
- Login SR with the factory default login ID "admin" and Password "setup"
You can also reset those routers by deleting the config file like this:
- Login as above
- type "SR > clear cfg_file system.cfg"
- message will read "removing contents of '/flash1/system.cfg' ...done.
- now type SR > reboot
How do I unlock voicemail on a hand set?
Enter the admin mailbox (usually FEATURE 981). Follow the prompts to enter the mailbox change menu for the box you need to reset and select the "reset password" function. This unlocks the box and sets the password to 0000, which will then prompt the user to enter a new password when the mailbox is opened. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/dave_fb2c45146b845cea
